Why would anyone use a DA for paint correction??
I used my GG on basically half of my firebird and cant notice a lick of difference from my rotary. Here is what I used on either machine
Rotary - Wool pad + Meguiars Deep Crystal Step 1, Black Foam pad and Meguiars Deep Crystal Step 2
GG DA - Yellow LC CCS Pad and Meguiars 105, Green LC CCS pad and 205.
I always FEEL like the rotary can do a better job but after using the DA and having the insurance that things cant go horribly wrong if I sneeze or trip on the chord it makes the DA look that much better.
someone send me a 3401 so i can check out this "aquired taste" good lord i want one....i dun have the moneys for one :(
Shawn
The only time I ever even think about my rotary is when working on boats and rvs or finishing a real soft pain in the butt paint like Acura NBP.
This thread was started about the time I was leaving work and I was interested to see where it went and it looks like it went just fine.
A couple of comments though...
So my question is, when do you guys use a da? Is there a purpose for it that I don't know about? Microfiber pads are a help but still the other technologies are far superior.
I love DA's and like you I started using a rotary buffer when I was at least 17 and I keep my first variable speed rotary buffer with me at all times because it fed me and paid my bills for a big chunk of my life. You can see it in some of the pictures in this thread on the back of the work bench, it's the blue Makita with the handle pointing towards the sky...
How to use a Rotary Buffer
Side of buffer worn smooth after years of buffing out paint
Lego man on my keychain reflecting off worn area on buffer
Here's what the head looked of the buffer looked like before. It has a rough texture because the aluminum was cast in a sand mold
But to your questions...
I use it when it's the right tool for the job and to introduce people that have always worked by hand to the wonderful world of machine polishing.
While you and others might not have had any hesitation about picking of a rotary buffer and buffing out a car, I'm here to tell you first hand after decades of teaching absolute newbies, some older than me some younger than me how to machine polish paint.
You can find pictures all over this forum and MOL with my hand on someone else's hand guiding them through their first machine polishing experience.
My how-to book is specifically focused on the Porter Cable "style" DA Polisher because from my experience in the detailing world, the normal progression for "most" people is to,
  • Start out working by hand. Most people already own a hand or two so that's what they use.
  • Progress to a PC "style" DA Polisher - Very affordable, pretty much "Bubba-Proof" unless you drop the thing on the hood of your car.
Then if a person is really into detailing as a hobby or a business (at some capacity), then they make the jump or progress to either a Flex 3401 or a Rotary Buffer. And this is a perfectly good way to go.
Besides the above, the PC style DA Polishers are very good at,
Buffing on paint and NOT leaving holograms
Removing holograms left by a rotary buffer
I don't even want to argue with anyone that's going to state how they are so great with a rotary buffer that the can leave a hologram free finish on EVERY car, or more specifically, EVER PAINT SYSTEM they work on because I don't believe it and I NEVER find anyone proving it.
In fact, to date no one has ever challenged anything I wrote in this article,
Hologram Free with a Rotary Buffer
No one.
Besides being an excellent tool for people to transition from working by hand to working by machine, and being an excellent tool for removing normal swirls and scratches and holograms inflicted into paint by the misuse of a rotary buffer, it's also a GREAT way to machine apply a wax.
I try do do as much of every project by machine and get my hand out of the picture and that includes machine applying a wax or paint sealant. The new coatings like EXO, Opti-Coat II and CQuartz require hand application and I'm okay with that but outside a hi-tech coating I'm machine applying everything.
With the right pads, polishes, and technique, DA's can equal or better the finish of a rotary on most paints in about the same amount of time....and they are 100% hologram free.
Exactly.
The way I type about it and explain it in my classes is by using a DA Polisher, (after a rotary buffer), you
Change the action of the tool
That means you go from a direct drive rotating action to a rotating and oscillating action and this type of action doesn't inflict holograms but in fact removes them.
Of course there is the problem of the potential for DA Haze, also called micro-marring or "Tick Marks" by Meguiar's Chemists, but this is not a negative, it's a factor to be inspected for on softer paint systems or when caused by the abrasive technology being used for the major correction step and then overcome by the next step and an experienced detailer or the help of a forum like this. I can insert links to examples of this all day...
The 3401 is an acquired taste. You may not like it at first but stick with it and you will learn to love it!
I would agree with this only because of the unique "walking" characteristic the tool has and that's because it oscillates under forced rotation. It basically teaches you to hold the pad flat and that's what you're supposed to be doing anyways. I also teach this in all my classes, that is how to properly use the Flex 3401 by holding the pad flat.
How To Polish a Street Rod! - Modeled by Stacy!
And it's definitely easier to use and control by upgrading to the 4" backing plate and then using the 5" Hybrid pads.
New 5" pads for 4" Backing Plate on Flex 3401
Live Broadcast Video - 1965 Plymouth Valiant - Extreme Makeover
I guess I need to go to Mike Phillips classes because I have not had the same experience.
Next class is January 26th and 27th and you will not only have a chance to use all the tools you read about here but you'll also get the chance to work on some really cool cars with them.
The rotary is ALWAYS MUCH FASTER and in my experience the maximum correction and gloss. I have not been able to do my car in less than 8 hours with the da versus 5-6 with a rotary.
I would agree and this is especially true after sanding down an entire car and it's time to remove your sanding marks.
You can remove sanding marks using any tool now that 3M, Meguiar's and Mirka all have #3000, #4000 and #5000 grit finishing discs on the market but here's what I always say about this topic,
It already takes a long time to buff out an entire car with a rotary buffer, (remove sanding marks out of an entire car), why would I want to do it any slower?
Again, can it be done with a PC and a microfiber disc? You bet! But it's going to be faster and more effective to simply take a wool pad on a rotary buffer and get it over with and then start the polishing process to create a show car finish.
Below is a K5 Blazer I led a team of guys to sand and buff out...
How to use Meguiar's Unigrit Sanding Blocks to remove runs and dirt nibs in paint
DA is just for final polishing or waxing, just something light duty.
Depending upon your experience level. If you're new to machine polishing and a little "worried" about causing harm to your baby you'll trade speed for safety. Keep in mind, there are a lot of people that are more than willing to learn how to machine polish their own cars to avoid the risk involved with taking their car to a so called professional detailer, just a do a search on this forum or MOL using the term,
Horror Story
As that's the term I coined, use and add to all my threads involving some pour soul that has had his cars completely swirled out by some hack detailer misusing a rotary buffer.
Some people are willing to learn how to use a DA Polisher and take care of their own cars to avoid the risk of a horror story happening to them but at the same time they don't want detailing to be their new hobby.
That's true. Rotaries do bring the speed factor to the table but with speed comes risk of accidentally burning through the paint on a high point or any place the paint is thin. Plus the hologram issue.
I have the Dewalt 849X too. I use it to jewel. I use the 3401 with MF pads, LC or Optimum. I know this is ass-backwards but I agree with Chad, a DA or the 3401 will correct hologram free in short order.
Here's an example people BRAND NEW to machine polishing using ONLY a Flex 3401. They performed two steps to correct the paint and restore a true show car finish and left zero holograms or swirls in the paint.
Pictures & Comments from September 2012 Detailing Boot Camp
BEFORE
Buffing without at the same time instilling holograms...
AFTER
Amazing results all things considered...
A rotary does cut faster, but it usually leaves behind a less than perfect finish.
The only time I really use it for cutting is when I'm wet sanding or working on extremely hard paint.
I agree and always love reading your write-ups showcasing your work.
CCS pads will actually have a better user experience, but flat pads produce better results.
I too am a flat pad fan. All foam pads work but I can make a case for a flat pad. Walter Cotton's work back in 1965 still endures today...
Only limitation for a DA i see is removal of sanding marks in corners and edges, where a rotary will be far more superior for this purpose.
And when buffing corners and edges with a rotary buffer, wool pad and compound you still have to work very carefully...
How to buff off an edge
But if you have the skill to finish properly with a rotary, then your blessed, you may have little use for your DA.
What I teach and practice (most of the time), is by finishing out using a DA Polisher you "ensure" a swirl free or hologram-free finish.
I do believe some "paint systems" can be buffed hologram free using only a rotary buffer but not all paint systems. The only way to know for sure though is to chemically strip the paint and then inspect it in bright overhead sunlight and the paint has to be a dark color or it can be difficult to really see what's going on at the surface level. What I find in the forum world is a lot of people stating they finish hologram-free but I never see the proof or a well written explanation describing how they chemically stripped the paint and then inspected. People just claim it.
I used my GG on basically half of my Firebird and cant notice a lick of difference from my rotary. Here is what I used on either machine
Neither of those chemicals are recommended for use with a rotary buffer. The Step 1 is barely abrasive, it's purposefully a very safe product for the average "Joe Consumer", it's also no longer made. The Step 2 is non-abrasive, kind of a cousin to #7 in that it's a pure polish.
Try those products with the rotary and you'll see some action.
Well said.
Big pictures is this, people are different and just like some people like Coke and some people like Pepsi, people are going to gravitate towards tools, pads and products that "they" feel comfortable with. There is no such thing as a one size fits all approach to machine polishing paint.
What's more important is to find what works best for you but always be open to new ideas, products and process.
Nice thread...
This is a nice thread.
I'll be starting on a black higher end Mercedes Benz today. The plan is to attempt to do the paint correction from cut to finish using a DA only with Lake Country UltraFiber pads on the cutting stage and foam pads to finish with. That's the plan in theory anyway.
I have been a rotary user for the most part but over time, watching guys like Rasky and C.Charles Hahn producing stellar results with the microfiber discs, I decided to push through the learning curve and have been creating some stellar results myself using these MF discs. The black Ceramiclear paint on this Benz will be the ultimate test of these UltraFiber discs.
It took quite a bit of time, frustration and many destroyed microfiber discs for me to "surrender" to the practice of switching out microfiber discs after each work section, to allow the discs to cool down as I'm using the next disc on the next work section. Since putting this plan into practice, I get more work done with less product used, fewer "if any" destroyed microfiber discs and zero holograms to clean up, or worse yet show up weeks after completing the job.
I'm pretty well stocked up on UltraFiber discs and lots of M-105, M-205 and Optimum Spray compound/polish. I never thought I would say this but my rotaries haven't had much play time at all lately. The more I practice with the MF discs and DA polishers, the less the rotaries come out of the cabinet.
A fact of my experience is that, if you use a rotary polisher day in and day out to make your living polishing cars, you will eventually make costly mistakes. I'm glad to see today's technology heading toward DA polishing, with the MF correction systems and the non-diminishing abrasives that are on the market. It certainly gets easier and safer to make a living doing this kind of work. My goal is to rarely "if ever", rely on my rotaries to get the work done.
Now...If "Cyclo Tool Makers" would just come out with a single head version of their polisher all would be well. However...it looks as if companies like Rupes may be addressing the issue of bringing a true professional grade "non forced rotation" DA to the market. I'll hold out for the reviews but something tells me that I'll have one in my arsenal before too long.
Have a wonderful day!!!
Thanks all for the great comparisons on all the different kinds of polishers out there. I know a lot was learned by some out there.
Thanks Mike. I have been using the 1 & 2 with my rotary for a few years now and never knew that. I may be able to put this GG DA down again someday and try the 105/205 with it, we will see.
Why would hollograms show up weeks after you were done? Because you didn't remove oils after compounding/polishing? Or because you just missed them?
Also- can you use a 3401 "on edge"? I've been doing it on my 350z without issues and had what I think are great results. There are some areas on the car that are simply too small to get the whole pad on there and while I know I *should* be using smaller pads I just don't have the cash for it, or just never got around to ordering the pads and backing plate yet. I'm fairly new to this so I don't have every tool/product under the sun yet; although I do have quite a bit.:)
Mike- I've read probably half your articles and your book in its entirety. I REALLY appreciate your passion for this work and it has helped me a lot. Thank you.
I'm sure it happens a lot more often then people think and most detailers don't realize it as the car is out the door long before they show up and the majority of vehicle owners don't know any better. I'd say it's most commonly from polishes filling or paint swelling and the detailer making to large of a jump in aggressiveness...like going from M105 on a twisted wool pad to M205 with a foam finishing pad and then calling it a day. Back in the 90's when I did high volume work I thought I was the $hit with a rotary buffer! It wasn't until I saw one of the black cars I detailed still on a used car lot a month or so later filled holograms! Often times our pride gets in the way and we are blind to the mistakes we are making. Having an experience like the one I had can be quite humbling.
Now days we have great forums like this one and professionals like Mike Phillips showing us how to do it correctly. :buffing:
No problemo... but just to comment... the Deep Crystal Line is a "Consumer Line" and most "Joe Consumer" type people work by hand.
The Professional Line are the products in the tan bottles with the numbers and these products are developed for and targeted at the professional side of the industry, so this would be what's called,
  • Refinishing - Painting, or re-painting cars
  • Reconditioning = Detailing cars
And because "Pros" are supposed to be knowing what they are doing, many of these products are in fact formulated for use with rotary buffer.
Why would holograms show up weeks after you were done? Because you didn't remove oils after compounding/polishing? Or because you just missed them?
Because even at the microscopic level, whatever it is you're using, that is whatever it is that's "touching" the paint in a rotating manner is imparting a scratch pattern. We call these holograms or rotary buffer swirls.
The oils, carrying agents, fillers, whatever), fills these microscopic scratches so when you look at the paint you see and think you left a perfect, swirl-free, hologram-free finish but that's not the case.
Now if you wax the car, (or apply a sealant or a coating), and then put the car in a museum or cover it and park it in your garage it should remain swirl free because whatever you used for a "protection" product is not wearing off.
If you put the car back into service and start driving it and then start washing it, just the act of washing a car with a soft wash mitt still micro-abrades the surface and the synergistic mix of car wash soap, wash media, rubbing, rinsing, etc. will act to start wearing off any substance off the surface and thus reveal the microscopic scratches we call holograms.
I've met more people in my life that brag about being the god of the rotary buffer, (not little g), than I care for because it's their pride boasting of their perceived skill building and maintaining their egos.
Like Chad aka RaskyR1 stated above,
A lot of times >you< don't see the swirls because the car and your work are long gone down the road and they don't show up till time plus wear-n-tear takes it's toll.
I've been humbled in my life with rotary buffer swirls as well as a lot of other things and eating crow isn't any fun. Pride goes before a fall.
Read enough of my posts and you'll see I believe that it's possible to create a 100% swirl-free finish using only a rotary buffer on "some" paint systems, but not all paint systems. It's not about "you" and your skill or products of choice, it's about the paint.
And this is why I always say that if you want to "ensure", and that's the key word, ensure, if you want to ensure a swirl free finish, then for the last machine polishing process you want to change the action of the tool and get away from a direct drive rotating action and switch to some type of tool that offers both rotating AND oscillating action.
Just my opinion on this topic after years of buffing out all types of paint in all conditions with all types of tools, pads and products.
Yes you can use a Flex 3401 on edge to reduce the size of the pad footprint and get into a curved area, buff a thin panel or focus more power to a stubborn defect but it's going to feel bouncy due to the forced oscillating action of the tool. As you already know, hold the tool firmly when doing this and be closer to the tool than farther away.
Thank you for the kind words... I type so many things on the forum but here's one that's not something I type all the time but it's also true... I have two passions in life, at least as it relates to my calling, that is the skills and talent I believe God has given me and that is to,
  • Polish out cars till they shine like no tomorrow
  • Teach others how to polish out cars like there's no tomorrow
And because this is my calling in life and my passion it comes out in my writing and in my videos and in my in-person classes. I hope it's come across in my TV appearances.
I agree with you on the above...
Back in the 90's when I did high volume work I thought I was the with a rotary buffer! It wasn't until I saw one of the black cars I detailed still on a used car lot a month or so later filled holograms!
Deja Vu - Been there done that, it's good to be humbled especially if you learn and remember the lesson.
Your way too kind and always a professional in business and your conduct on public forums like this which is a testimony to your good character. You've come a long ways and I know you're going to be very successful into the future no matter what it may hold...
:dblthumb2:
I'm sure it happens a lot more often then people think and most detailers don't realize it as the car is out the door long before they show up and the majority of vehicle owners don't know any better. I'd say it's most commonly from polishes filling or paint swelling and the detailer making to large of a jump in aggressiveness...like going from M105 on a twisted wool pad to M205 with a foam finishing pad and then calling it a day. Back in the 90's when I did high volume work I thought I was the with a rotary buffer! It wasn't until I saw one of the black cars I detailed still on a used car lot a month or so later filled holograms! Often times our pride gets in the way and we are blind to the mistakes we are making. Having an experience like the one I had can be quite humbling.
This is just part of the experience of many detailers who do this work year after year. Myself, I had this humbling experience with a black Corvette. The first C-5 I worked on in fact. The car looked awesome both to myself and the customer. I used IPA to wipe the oils off of the paint to ensure I was getting the correction that I was shooting for and all was good (or so we thought).
The Corvette owner never noticed the holograms but upon bring it to me a year later, in prep for a "cruise in" down in Ocean City MD, I saw the holograms immediately. I have added a 105 step using a DA polisher to follow the rotary step and before the finishing step on hard clear cars such as Corvettes to make sure this doesn't happen again.
This black Ceramiclear Benz I'm working on now is a slow go working with 105 and the Ultrafiber discs but it's coming out really nice with no chance of holograms re-appearing in the future. I've taken a few of the UltraFiber discs past their limit, getting them too hot where the foam kind of gets so hot that they're loosing a bit of their thickness but they're not separating on me.
Someday I'll have mastered the use of them and will likely work with a DA exclusively.
Great post Davy, thank you for chiming in...
:dblthumb2:
I must say that I've thoroughly enjoyed this thread.
Many of you know that I'm working on a black "Trashed Trailblazer" (<<<do a search) and tomorrow I am hoping to have most of it completed, and surely by Friday, 11-28-12. That is if the weather will cooperate and no one asks me to do anything for them...which has happened quite often lately...and I always drop what I am doing. It's just what I do.
Anyhow, I had made a recent post asking questions about using the rotary to do the majority of the rest of the resto work on this project...if for nothing else to save time and beat ol' man winter.
I am absolutely loving using the rotary on paint, especially oxidized black paint. The paint and tools are teaching me, and I love the learning process. However, I have no plans, now or in the future, of ever needing to prove to myself how good I can get with a rotary. Why would I need to try that and prove anything to myself. As Mr. Phillips so nicely put it, it's not about me, or how good I am. It is most certainly about the paint and doing the best quality of work.
I try my best to be observant of people who have traveled certain paths. By paths, I mean people who have made mistakes. There are plenty of DISO (that's is...Dealer Installed Swirl Option or Detailer Installed Swirl Option) photo's on this forum and others where people who either don't know (uninformed and unintentionally a hack), or don't care (hacks and don't care to be), about what a project looks like a week or a month later as long as it looks great going out the door. That's not me, and never has been with anything I've ever done. If a person can't do it right the first time when will that person have time to do it right the second time? The answer to that question is, never.
So, again, there are plenty of photo's to back-up what Mr. Phillips teaches. In that regard, I try and learn from other people as much as I can.
In my own classes that I teach (a different field) I tell my students that you can learn much just by watching other people and/or students and how they work. I explain to students that they can not only learn from me, but they can also learn from others if they watch what a fellow student is doing. They can learn from what that person doing, whether what that person is doing it correct, or not. I tell those students that;
"There's always something to learn, even if it's what not to do, all you have to do is pay attention." -W.S.S. (<<<to quote myself, Hoytman)
You do this by watching and asking yourself and others commone sense questions.
I believe it was Elanore Roosevelt who said something like this, paraphrasing of course; Learn from the mistakes of others because you can't live long enough to make them all yourself.
With that, I'll certainly employ the use of a dual action polisher to finish out any of my work. It simply makes good sense.
is there any MF correcting system that is suited and works well with the flex 3401?
