Will this work well with the foam cannon?
After much research I bought the TaskForce from loves to use with
the foam gun and found it to be great--including all the things I
use it for at home. Also, Lowes warranties things well.
Accepts the Bosch fitting.
Good Foaming
This is the one I'd prefer to get because it has a bit of a higher PSI rating and it's a little cheaper. Most of the reviews I've read have been bad though...........this hasn't given you any problems?
Task Force 2000 PSI
Does anyone know if there is an adapter out there for this powerwasher (TF2000) to hook up a foam cannon? I've looked everywhere and cannot find anything. Anyone's input is appreciated. I think I have the last surviving unit in the world...lol.
Just fyi in case anyone else runs into this. I found the Greenworks lance works in the kit that Lowe's sells for $34.99.
Shop Greenworks Plastic Gun Kit at Lowes.com
I tried the Bosch adapter but it got stuck in my gun so I had to go another route to get this to work.
