Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
Ok, I know Mike P says you can use any polishing product for paint on glass. I get that.
The context of when I say that is when I'm talking about removing
- Road film
- Topical water spots
- Surface impurities
The above are foreign substances ON the glass.
When working for defects IN the glass you must use a glass polish that contains Cerium Oxide like CarPro Ceriglass
And - sometimes even if the defects are on the surface you might not be able to see all the microscopic defects that have built up on the glass surface so a good polishing with a cerium oxide glass polish would be the remedy.
Glass polishing - How to remove scratches in glass
In the picture below you will see the pads, products and tools you need to remove scratches from glass.
Glass is very hard and in order to abrade it in a way to remove scratches without at the same time instilling scratches you need a polish specifically made for glass that contain
Cerium Oxide
Full step-by-step here
