creaky
- Sep 30, 2013
- 116
I recently finished with three layers of Ultima Paint Guard Plus sealant as my main barrier of protection for the winter. I want to figure out what can be done additionally to make sure I get through the winter with the UPGP intact so that I can strip it and get another set of layers on there when the weather will let up, probably in April. So, that's 5+ months. My main question is, Is 5+ months realistic for UPGP on a DD that will likely get a wash every 1-2 weeks with a "pay and spray" or touchless car wash?
If I were to fortify the layers what would be the best way to do so:
- Add a coat of wax now on top of the UPGP?
- Add a layer of optimum car wax spray after each wash?
And if I do either of those, I don't think adding additional layers of UPGP later would work since it wouldn't bond correctly. So, am I better off just forgoing the wax products all together and just adding more layers of UPGP (which itself might not work due to low temperatures - I have read that below 50 degrees there are problems).
Or is there something I'm missing here altogether?
In a perfect work I would do a rinseless wash with ONR after spraying off the car with water that the pay and spray, but that is probably not realistic here in the dead of winter. So, I'm looking for the best way forward.
Thanks in advance for input.
