Pimpmobile
- Mar 19, 2017
- 70
In addition to applying a durable LSP of your choosing to protect the paint against old man winter I'm sharing one great method I use as well. What I like to do is apply fluid film which can be bought at lowes in a spray can to the entire under side of a vehicle. I also like to spray it in th engine compartment and door jambs. By doing this you protect the under side from the damaging effects of road salt . You can read a lot of stories about this on the web and I always apply fluid film in November before the first snow fall . Then give the underside a good blast with a hose or pressure washer after driving through a snow storm . Just spray everywhere underneath floor pan brake lines frame rails etc. The stuff lasts all winter. You should not neglect your under carriage
