Wiper Blades
Just threw on a a pair of the TRICO FLEX. So far a good blade. TRICO for the rear also.
These replace the MICHELIN STEALTH. Best blades I have encountered so far.
Another vote for the Bosch Icons. I just replaced mine after 2 years of Florida weather. I park in a garage at work, but otherwise the truck is outside. I do clean them (when I remember) with the little wipes you pick up at restaurants.
I always had an issue with a 'missed' spot on the drivers when I purchased the original pair of "A" inserts. After getting the same thing with the new pair, I grabbed a "B" insert (for only $9.99) and it worked perfectly.
I use rain x they are the beam style. I've had the same set for two years and still work like new. I wipe them with IPA and treat with 303 from time to time
Sent from my Z982 using Autogeekonline mobile app
