Wiperblade treatment/s
rabbi
Does anyone use or had used a wiperblade treatment? I'm interested in your opinions and findings. Thank you in advance. Rick
Look what the dog dragged in. Hi Rabbi, nice to see you here. I've just recently tried some 303 wiper blade treatment. The blades are about 9 months old after applying they work like new. I haven't had it on long enough to know if this stuff lasts.
Most vinyl rubber treatments like Meg's...Pinnicle...303...Klasse...and so forth will keep the blades from drying out and pliable....and in good condition....just put some a MF or a piece of foam and apply to blade..do it monthly and you will be set...
GM makes a washer solution called Optikleer...it has stuff in it to keep blades supple...I get it at the dealer...is 2.95 a gallon..or the conentrate is 5.00 for 32oz...makes close to 3 gallons....it does leave the glass cyrstal clear....
Al
I just replace the blades annually ... usually with factory replacements but did run the PIAA's with nice results in the past.
Interesting topic. I was looking at some Bosch Icons. Does anyone have any experience with them?
