Im confused slightly...
the product description reads that you should apply the sealant spritz and then fuzion, but later, it mentions using the spritz over fuzion as a qd instead... i know it can be used both ways, but the thought of a sealant over fuzion has me flustered a bit...
This spray-on sealant is a revolution in paint protection! Wolfgang Deep Gloss Spritz Sealant is a direct descendant of our ground-breaking wipe-on sealant, Wolfgang Deep Gloss Paint Sealant. The two share virtually the same blueprint, with one exception. Deep Gloss Spritz Sealant has engineered liquefied polymers that disperse easily through the spray nozzle and then cross-link on the paint surface to form one solid polymer coat over the paint finish.
If you really want to kick up the shine on your paint, apply a layer of Wolfgang Füzion Wax over Wolfgang Deep Gloss Spritz Sealant after the sealant has cured. You’ll get the long-lasting protection of the sealant and the warm glow of carnauba.
then this:
then this:
Wolfgang Deep Gloss Spritz Sealant maintains the gloss and protection of Wolfgang Füzion Wax.
