I bought this product to try it out since I read many uses and different dilution ratios can be made for different applications; I have my car coated with ceramic paint protection (similar to CQuartz) + Applied on top paint sealant (Car Pro Reload), and the cleaning procedure is simpler IMO, as I wash with water pressure (A Lot) only for the paint work, no serious contamination on the paint, as the car gets dust or possibly sandy over here in this region, so simple water pressure or even air blowing gets most of the dust and sand off, after am fairly confident most of the dust is off, i use plush microfibers, soak them in water, squeeze then dry the car to minimize friction and possibly scratches/swirls on the ceramic paint protection layer, but id really like to spray some sort of quick detailer / drying aid BEFORE going through the drying process to lubricate the surface even further, prevent water spots, and thus maintaining the ceramic coating even longer...
Not sure of the exact terminology used here whether it is a quick detailer I need, drying, waterless etc... But I hope you got the picture ??...
Any advice of the correct dilution ratio is appreciated as I don't want to miss things on my First try doing this...
