Wolfgang Swirl Remover, Glaze and Polish enhancer
thatick
If im doing a total detail, would i use all 3 of these products (swirl remover, then glaze, then enhancer) followed by a sealant or wax. Im just a little confused with these 3 products. Thanks
If you are using the first 2 steps, then the last step(PPE) is not needed.
Great question!
Normally when detailing a car you would do a few or all of the below steps,
  1. Wash and dry
  2. Clay the surface if needed
  3. Clean the surface and/or remove below surface defects
  4. Polish the surface to a high gloss
  5. Seal the surface with either a wax or a paint sealant
For the 3rd step if you had swirls and scratches, you would use the Wolfgang Total Swirl Remover
If the paint is in pretty good shape then could skip the swirl remover and just prep the paint with either the Wolfgang Paintwork Polish Enhancer or you could use the Finishing Glaze.
The Total Swirl Remover and Finishing Glaze are often referred to as the Wolfgang Twins because they compliment one another and are most often used with a Dual Action Polisher to restore a show car shine to neglected paint.
The Paintwork Polish Enhancer tends to appeal to people that want to work by hand but it too can be used with a DA Polisher.
Thats what i was leaning towards but i wanted to make sure. Thanks for the help
MMM---maybe I have been doing this wrong = ==Newbe here...
Step 1--wash & dry
2--Clay
3--Swirl Remover
4--WGPP Enhancer
5--Glaze
6--Polish
7--Wax
As you Guys can tell Im really new to this....Are these the steps to go by???
Step 1--wash & dry
2--Clay
3--Swirl Remover
4--WGPP Enhancer
5--Glaze
6--Polish
7--Wax
Take out step #4 and #6. You are taling about the wolfgang glaze right? It is a finishing polish.
Here is what I did today, took ~7hrs total.
1. Wash and Dry
2. Wolfgang Total Swirl Remover (Orange CCS Pad)
2.5 Klasse All in One Polish on hard to reach/not too noticeable areas
3. Wolfgang Finishing Glaze (White CCS Pad)
4. Pinnacle's Liquid Sourveran Wax
I did not clay since the paint still felt smooth. It turned out well, not perfect, but I'm satisfied for the time it took. I did this on my DD, 2010 Toyota Corolla Barcelona Metallic Red.
could the glaze be parallel to M205? or even Menz 203 for that matter?
Just a question is my first real detail is in order , once i recive all my stuff that i ordered today. Normally when detailing a car you would do all of the below steps,
Wash and dry
Clay the surface with Riccardo yellow
Clean the surface with Total Swirl Remover
Polish the surface with Finishing Glaze
Seal the surface Wolfgang Deep Gloss Paint Sealant 3.0 Also should i use Wolfgang Deep Gloss Spritz Sealant or skip it / I will be using Cobra Micro Fiber Towels and Lake Country Buffing Pads but i'm not sure which ones i should buy. My car color is dark Graphite Pearl
Sounds good! I know you meant polish with TSR and polish(finishing) with finishing glaze. I would get a couple of each pad(orange, white, soft green, grey and blue). You never know when you'll need them, but you eventually will. I'd say for you to look into the LC HT pads, but people have been having a lot of problems with them ripping.
You don't need the spritz. I would get a good quick detail spry though.
thank you for answer, is there any other good quality pads that are just as good as LC HT pads
I forgot to ask what machine you are using. For a DA, I would go for the 5.5 inch LC flat pads. If you have a flex 6.5 inch flat are fine.
Wash and dry
Apply one thin coat of sealant. Let cure for 12 hours. Apply second thin coat. Let cure 12 hours. If you like, top with a coat of carnuba.
Spritz sealant not needed at this stage.
looking to buy a new beginner DA machine thinking about P.C The 7424XP i think it should be right now i can't afford Flex
