Wool pads with DA?
There is no set polish/pad combo. Just some polishes work better with a given pad than others. You need to play around with different combos to get the results you want. Since sip is a medium type polish, not a finishing polish like you stated in your othere thread it will need to be finished up with a finishing polish and pad. I would picj up the foamed wool and yellow pads since you are only working with a pc. You will have to to this in steps and this should make a difference in the condition your hood is in.
