XMT Pad Cleaner & Pinnacle Micro Rejuvenator
  • Thread starter Thread starter D
  • Start date Start date
D
Whats the difference between these two products? They look the same and smell the same.
Either way, both work great for me!
Don't know, I've only used the XMT pad cleaner. Like it so much I trieded some product for more.
XMT Pad Cleaner is for pads and Pinnacle Micro Rejuvenator is for mfs. I use both of them and they both work really well.
never really noted the look or smell, both work wonders however. As said above, one designed for foam pads other for microfibers. I would suspect one is a lighter version for laundry use.
Yes, I realize one is made for pads and another for mf. I was just curious what the difference is since they LOOK the same.
Use em both. Love em both.
Got a new sytem with XMT Pad Cleaner. After the dirty pad is sprayed add a small amount of water to the pad and knead it in deep. You'll get some light suds. Let sit and then rinse. My stained pads look almost new doing this.
I rinse mine with hot water first for a couple min. Spray on the pad cleaner, let it sit for a couple seconds, then scrub.
