XMT360 AIO Big Problems - Need some advice
Here are some tips from my experience using XMT360.
1. Prime the pad, but then use the product sparingly. Just as with most products, less is more.
2. work it a full 5-6 section passes. If you work the product down completely, it will leave virtually no trace, and if there is any left behind, it should wipe off easily.
3. Do not let the pad get over saturated with product and product residue, so therefore clean the pad after every few sections.
4. This should go without saying, but make sure you shake the bottle well :)
I am of the thought that 360 has very little correction ability. However, it is a good product that is relatively easy to use and for the most part works as advertised.
Turned out it was user error on my part. I did not prime the pad and drybuffed the car! Thanks for the help guys. I'm correcting it now.
Are you priming your pad? When I first started I put buffer trails into the clear coat (my girlfriend's soft paint Nissan) with a DA by dry buffing (aka not using enough product).
Hey I called it! :D
Here is the Show and Shine with my corrected results. I would like to thank everyone for their help!
http://www.autogeekonline.net/forum/show-n-shine/60851-wrx-detail-w-autogeek-forum-rescue.html
Drew
Looks good, but yeah as you said, you might have to live with the towel marks unfortunately. Maybe you could try a glaze?
Hey I called it! :D
You did call it! I had buffer swirls all over the bumper as well just like you did. I took it out this morning before I corrected it w/205 and it was spotted up like a dalmatian!! Looks so much better now!
Looks like Meguiar's saved the day, again. Glad it worked out for you!
