This happened to my Acura TL about a month ago. I ran over some freshly painted lines pulling out of a parking lot one night. All four of my wheel wells were covered in yellow specks. It also got some on the paint around the wheels, but it was not a lot. Like PAR mentioned, this paint is not what you would typically think of as paint, it was actually thousands of tiny little sticky yellow "specks". It is also designed not to wear off, so as you can imagine, removing it is fun!
I used a claybar to get the specks off the paint, and that turned out not to be a big deal. It came off pretty easily.
The wheel wells, however, were a huge pain because there was so much more paint there and a much tighter space to work in. They also have ridges and spots where the yellow paint got stuck in. Since I didn't want to waste clay, I tried car wash soap, ARO, APC+ diluted and full strength, and each time scrubbed with a wheel well brush. The APC+ full strength seemed to work the best, but it still did very little. Eventually I went to the store and picked up a couple cheap toothbrushes and used them to scrub all the cracks and ridges. As I loosened up the specks, I rinsed frequently with water from a two gallon garden sprayer (I imagine having a pressure washer would be a real advantage here). The annoying thing is that the paint would come off, then stick again as I was spraying water. The process took literally hours, but I got them clean.
Another consideration is that you have to clean up the water and paint around the car that you've removed, or you will drive over it and transfer it right back onto the wheel wells.
Best of luck and hope you have an easier time than I did with it.
