Yellow road paint
van185
I got a detail over the weekend with yellow paint from a newly painted road all over the wheel wells. There was probably more paint in the wheel wells than left on the roadway. I tried a lot of different pproducts and had no luck. I finally went to a plastic razor blade and it took most of the day. Does anyone know the best ways to remove highway paint?
Why did you try?
I have had success with:
Enamel paint reducer.
Lacquer thinner (Use sparingly).
I washed the car with power washer to remove any loose paint then I tried tarminator and goof off with plush micro fibers. The goof off worked really well and the tarminator worked ok. Hope this helps
Chad@Divine Details
simple buy 2 cans of underwheel spray on they will look like new in 15 minutes. i speak from experience. looks brand new. napa or any auto parts house will have this
Thanks for the advice. I tried tarminator, goof off, Tar-X, and Mineral Spirits all with no luck. The plastic razor blade and about 3 hours worth of work was the best option I found. I should have tried the underwheel paint.
I always check these threads for an update or in hopes that one day someone will go, "hey, I know what's in there!"
Years ago I had the same problem. I tried everything and nothing worked. Finally, one winter months later, I kick a bunch of caked up snow/ice/road salt/calcium brine mixture (?) out of the wheelwell, and, VOILA! all of the yellow paint was gone with it, stuck to the ice.
This is in NJ/PA/DE, mostly NJ. I'm not 100% sure what they use on the roads, but I imagine it's some kind of mix between the salt and the calcium brine solution.
:dunno:
Believe it or not, I've had good look with Xenit.
Stoner XENIT Natural Citrus Mold Cleaner
Stoner XENIT Natural Citrus Mold Cleaner removes resins, carbon deposits, silicones, and contaminants from molds. You’ll never again be frustrated trying to remove tough gunk and grime in your home, office, garage or car. Natural citrus XENIT by Stoner removes tacky, grimy dirt so well, in most cases you can simply “wipe it away.”
Xenit is a natural precision mold cleaner used as a degreaser in the plastics and rubber molding industries. It contains Citrus 66, a highly refine extract of citrus fruit. This powerful ingredient removes greasy soil and stains that can't be removed by soap and water.
Use XENIT to quickly permanent marker, crayon and lipstick “accidents” in the car and around the home. It removes release agents, resins, carbon deposits, and other contaminants left in mold cavities.
Xenit contains more than five, different, high performance cleaners. Unlike most water-based citrus cleaners that are designed to lift and carry dirt, XENIT is formulated to break down the complex molecules found in sticky materials. This MicroActive cleaning action gives XENIT unequaled abilities to loosen and dissolve difficult grime like tar, grease, gum and adhesives. It even removes dried latex paint if accidentally dripped on carpet, flooring, or furniture. Xenit removes shoe scuffs and heel marks from from vinyl panels and greasy dirt from fabrics and upholstery.
Save yourself hours of agony trying to remove sticky stuff with standard cleaners. Avoid wasted time spent laboring with inferior water-based products. XENIT is formulated to evaporate and dry completely, leaving behind no sticky residues or streaky soaps.
10 oz. aerosol.
:xyxthumbs:
