Foam is fun!! I like to put enough on my car so that you can not tell a car is underneath. Im the MAN
-Foaming/sudsing (snow-foaming?)...while very satisfying and fun to many folks,
may not be an end-all as a
"solution" to achieving a clean vehicle.
For a really good vehicle-cleaning-session doesn't/wouldn't one still need to agitate
the car-washing solution---be it in the form of lots of foam/suds, or not...
in order to remove, hopefully, surfactant-causing, encapsulated/emulsified-contaminates.
-Often, blasting away the foam with a pressure-washer/pressure-washer-with-brush-attachment is recommended
for removal of all the foam/suds generated by whatever
'foam-machine' used.
(Without, which, just might provide a hindrance to the necessary hand-washing session that, indeed, must follow.)
-Also...
Excess foam/suds might create a hardship for Detailers that are practitioners of water-reclamation requirements.
-OH Well!...Since there seems to be followers of the trend towards more usage of "pre-wax cleaners"...
I suppose I can see/realize the correlation in the followers of the trend towards: "pre-wash cleaners"?
(What? Wash before you wash?)
-And here I thought/believed that:
"The Case of the Ivory Snow Flakes" ~ Perry Mason...
had already been adjudicated!!
