1955 chevrolet BelAir
prin
Member
This car was brought to us by a good friend needing a make over. It was restored about 30 years ago and like most cars that were restored in that era, this one has remained unchanged. From the interior to the original Truespoke wire wheels, this car is a true time capsule.
The paint choice was single staged lacquer. Therefore, we spent many hours gently and carefully massaging the paint. First, we rebadged the hood and trunk lids. We started by applying Meguiars #7 that is made especially for this type of paint. It’s purpose is rejuvenation of older single staged paint so that it will be easier to work with. We let that soak for about 20 hours. Once removed, we began our correction process. Very carefully, we were able to remove the aging process of this paint. All swirls as well as other paint defects were removed by using Wolfgang’s swirl remover. We noticed some panels had “solvent pop” which occurs when the solvent in the paint evaporates too quickly. The end result will be tiny pin holes or even blisters in the paint. There isn’t anything that you can do for this. Therefore, we worked very carefully around it. Thanks for the advice Mike!!!!
The inside of this Bel Air is very well dated and we love it!! It was thoroughly cleaned, polished, and protected. Since this is a 30 year old build, most, if not all of the chrome were pitted. We were able to correct that process and polished all of the chrome. All of the metal and painted surfaces inside were polished and protected.
The wheels were thoroughly cleaned as well. After cleaning, we were able to polish off all of the rust. We really wanted to save these 30 year old wheels. I think that we succeeded in the process!!!
This car is a true time capsule!!! It shows exactly what we can do for your ride. It is your investment and it should be protected!!!
There were a plethora of different items and products used in this process. For the paint, it was cleaned
Here is the no.7 soaking in...
Nice job on the ‘55 Chevy... :props:
Love the ‘55 Chevys.
The ‘55 Chevy was my first car.
Awesome work and write up and pictures prin!
One of my favorite cars the Bel Air -55! Would love to try out the #7 method sometime. Gonna be to import it though as Meguiars Sweden doesn't carry it sadly. But one of these days maybe I get a owner with a paint suited for a #7 treatment.
Looking beutieful!
/ Tony
Great work Prin! Nicely done and the owner should be super proud of how his Chevy looks now!
Nice Job, Prin!
What have you found to be the best method of cleaning spoke wheels like that?
Nice Job, Prin!
Time! LOL, we spent a lot of time trying to get them to look their best. I used a lot of steel wool, Zephr's Pro 40, and APC
Beautiful work!!!!! Beautiful car!!!!!! I love it!!!!!
-Looking at the trim configuration, the car looks like a 510 post sedanette that they stuck Bel Air emblems to. Normally the Bel Air had the extra little piece of trim that goes from the back of the 1/4 trim down to the rear bumper to create a full break/separation point for the 2-tone option. I am sure some of the older generation on here can correct me on this.
the car looks like a 510 post sedanette...
a 510 post sedanette?
-Speaking from the position of being a life-long
Chevy fanboy (including the privilege of owning
a ‘55 Chevy BelAir as my first vehicle) that’s a
designation, that this proud member of the older
generation on here, has never heard of before.
However:
•If it is:
-it’s gonna probably be worth a small fortune!
Thanks for posting this, the 55 is the best of the tri-5's. Excellent work.
