DARK HORSE
Active member
- Sep 14, 2009
- 2,537
This 1982 Datsun 310 was given to my youngest son (Andrew) by a family friend. (He will be old enough to take drivers training this summer). The car belonged to our friend’s dad who passed away three years ago. (The car has sat for several years). His dad purchased the car to drive back and forth to work only (he had another car that he kept for everything else). He worked for the Railroad (rail yard), so this car was parked at the rail yard virtually every day for over 20 years. While he took care of it mechanically very well; the cosmetics (interior/exterior) were very much neglected. Mechanically the car was in great shape for being 28 years old. It only has 82K miles on the clock. My son and I have had a lot of fun working on it together. In addition to the correction work, we also had to replace the battery, battery cables/terminals, rebuild the starter, do a front/rear brake job, troubleshoot and fix a few minor things, refurbish the wheels and replace the tires that were dry rotted. We thought it would be fun to try to correct the vehicle as much as we could and make it as nice as we could for him to drive while he is saving money for a cooler car (I agreed to mach whatever money he saves). I know the car is far from new or fancy, but my son did most all of the work, (with my supervision) and thought it would be pretty cool to post it. Anyway here we go:
Engine Bay: We cleaned the engine bay with ARO (Amazing Roll Off) and various scrub brushes. The rubber hoses were in very bad shape (extremely dried out), so we rehydrated, and dressed them using Optimum Opti-bond Tire Gel.
Here are a couple of shots:
Tires/wheels/wheel wells: Tires were dry rotted so badly that we decided to replace them. (New ones were cleaned with Megs. APC+ and dressed with Optimum Opti-tire bond). Wheels were so rusted that we cleaned them with ARO, primed them, sprayed them with several coats of gloss black, and several more coats of clear. Wheel wells were also cleaned with ARO and dressed with a cheap aerosol tire shine spray.
Here’s Andrew hard at it…
First Wash: The first wash was nothing special, as the paint finish was so trashed that there was really no need to observe proper washing techniques. Andrew washed the paint (multiple times) with DP auto bath (one bucket) and a Plush Cobra MF. He then dried with a Cobra WW MF.
Clay: He then clayed the car with DP universal detailing clay, using ONR mixed a 1:32 with distilled water for clay lube.
Paint Correction(We chose the following):
Step 1 = m105 and several cyan hydrotech pads (91% IPA wipe down).
Step 2 = m205 and several tangerine hydrotech pads (91% IPA wipe down).
(We used PakShak microfiber “Ultra edgeless white towels” for polish removal and PakShak ultra plush towels for IPA wipe downs).
Here are some shots before, during, and after the polishing stages:
Here’s Andrew getting down with the PC…
Some serious below surface contaminants (This is after multiple washings and clay barring sessions on both sides. The right side is after a few passes w/ m105 and a cyan hydrotech)…
After several passes with m105/cyan and several passes with m205/tangerine…
Some more serious below surface contaminants…
