AL417 said:Nice job on that Mustang. Sucks to see someone scratching something into a cars finish. I was about to ask you where you were in IL but you changed your profile and added Chicago. Thanks! There's a bunch of us around here.
About the XMT line, I use it a lot and don't get any dusting. I've read the posts about dusting and I don't know why some users are getting dust.
Nimble said:I don't use the XMT products, so I can't make that call, but I can definitely tell you OC is not as aggressive as XMT4 from what I've read, but probably a *bit* more aggressive than XMT3. I've tried and did not like the PB's polishes and all I've heard is the XMT line is about the same, works but dusts. See Optimum works even better than any dusting polish I've tried, and even when the pads build up, only them will OC *very* ever so slightly dust. They rock when you're trying to keep your garage clean.
I bet OHC is on par with the XMT4 though, as it is known to take anything out, especialy with a rotary. For super high quality polishes that dust a bit, but work sickly well, try Chemical Guy's Diamond Cut 1500, or Four Star body shop Medium Cut Compound. I only use a PC, so anything more aggressive than that won't break down.
