Whats the MSDS on this? What disease does this cause?
Chemical Guys CLD_1010 - All Clean All Purpose Cleaner & Degreaser
No MSDS is available to me...But:
According to Chemical Guys their
"All Clean APC & Degreaser" is a:
Surfactant based cleaner that contains wetting agents
(Sounds like some gobbledygook/double-speak the Government uses!)
Which surfactant(s) and which wetting Agent(s) is unknown to me at this time.
Definition of Surfactants:
-Compounds that lower the surface tension between two liquids or between a liquid and a solid.
Surfactants may act as detergents,
wetting agents, emulsifiers, foaming agents, and dispersants
Types of Surfactants: Nonionic, Anionic, Cationic, Zwitterionic, even Hydrotropes
LISTs OF SURFACTANTS
I.
Polysorbates
Sodium dodecyl sulfate (sodium lauryl sulfate)
Lauryl dimethyl amine oxide
Cetyltrimethylammonium bromide (CTAB)
Polyethoxylated alcohols
Polyoxyethylene sorbitan
Octoxynol
N, N - dimethyldodecylamine-N-oxide
Hexadecyltrimethylammonium bromide (HTAB)
Polyoxyl 10 lauryl ether
Bile salts (sodium deoxycholate, sodium cholate)
Polyoxyl castor oil
Nonylphenol ethoxylate
Cyclodextrins
Lecithin
Methylbenzethonium chloride
II.
ANIONIC TYPES
1. CARBOXYLATES
2. SULPHONATES
3.a. PETROLEUM SULPHONATES
3. b. ALKYLBENZENESULPHONATES
4. NAPHTHALENESULPHONATES
5. OLEFIN SULPHONATES
6. ALKYL SULPHATES
7. SULPHATES
8. SULPHATED NATURAL OILS & FATS.
9. SULPHATED ESTERS
10. SULPHATED ALKANOLAMIDES
11. ALKYLPHENOLS, ETHOXYLATED & SULPHATED.
NONIONIC TYPE
1. ETHOXYLATED ALIPHATIC ALCOHOL
2.POLYOXYETHYLENE SURFACTANTS
3.CARBOXYLIC ESTERS
4. POLYETHYLENE GLYCOL ESTERS
5. ANHYDROSORBITOL ESTER & IT'S ETHOXYLATED DERIVATIVES
6. GLYCOL ESTERS OF FATTY ACIDS
7. CARBOXYLIC AMIDES
8. MONOALKANOLAMINE CONDENSATES
9. POLYOXYETHYLENE FATTY ACID AMIDES.
CATIONIC TYPE
1. QUATERNARY AMMONIUM SALTS
2. AMINES WITH AMIDE LINKAGES
3. POLYOXYETHYLENE ALKYL & ALICYCLIC AMINES
4.N,N,N',N' TETRAKIS SUBSTITUTED ETHYLENEDIAMINES
5. 2- ALKYL 1- HYDROXETHYL 2-IMIDAZOLINES.
AMPHOTERIC TYPE
AMPHOTERIC SURFACTANTS CONTAINS BOTH AN ACIDIC & A BASICHYDROPHILIC MOIETY IN THEIR SURFACE e.g.,
1. N -COCO 3-AMINOPROPIONIC ACID/ SODIUM SALT
2. N-TALLOW 3 -IMINODIPROPIONATE, DISODIUM SALT
3. N-CARBOXYMETHYL N DIMETHYL N-9 OCTADECENYL AMMONIUM HYDROXIDE.
4.N-COCOAMIDETHYL N HYDROXYETHYLGLYCINE, SODIUM SALT, etc.
____________________________________________________________________________________________________
Wetting agent:
-A chemical agent that allows a liquid to spread more easily across or into a surface by lowering the liquid's surface tension
Wetting agents can be surfactants; conversely: surfactants can be weting agents.
An Example: Sodium Lauryl Sulfate
Health Risks:
In the same way as it dissolves the grease on car engines,
sodium lauryl sulfate also
dissolves the oils on your skin, which can cause a drying effect.
It is also well documented that it denatures skin proteins, which causes not only irritation,
but also allows environmental contaminants easier access to the lower, sensitive layers of the skin.
Perhaps most worryingly,
SLS is also absorbed into the body from skin application.
Once it has been absorbed, one of the main effects of
sodium lauryl sulfate is to mimic
the activity of the hormone Oestrogen. This has many health implications and may be responsible
for a variety of health problems, from PMS and Menopausal symptoms, to dropping male fertility
and increasing female cancers such as breast cancer, where oestrogen levels are known to be high.
APC's/cleaning products' chemicals don't paint a pretty picture by any means.
I recommend to be responsible, and prudent, in their usage.
