2012 Kona Blue Ford Mustang - Waxin' Willys Detailing
how do you have it finishing so nicely?
M105 finishes excellent if you use good technique, even on soft paint. 95% of compounds won't finish as nicely as M105. The paint looks great as it stands. I wouldn't have bothered following M105 with anything else, either. Nice job. :dblthumb2:
What polisher did you use?
Big reason M105 is worth learning how to use!
Sent from my iPhone using AG Online
Like others have said, M105 finishes very nicely if used correctly. I've had problems with dusting on 105 and have solved the problem by spraying my pad down with a little bit of distilled water. It gives me more working time, makes it come off easier and leaves a fantastic finish
True, you really don't need to follow anything, but I wanted to make sure I had a good surface for the RejeX
I used a 7424 XP
:dblthumb2:
Haha thanks, sorry if I came off rude, didn't mean to! Im the MAN
So you spray the pad before each section with distilled water?
I like the business name you went with!
Not on each section...I spray it down before I start and then when I notice it starting to dust a lot I spray it again. It usually needs more moisture every 4-5 sections
