2020 BMW M340i - CarPro CQuartz UK 3.0 and Gliss
gofast182
First of all I'd like to thank everyone who posted in my "help me decide what to use" thread, particularly The Guz who helped give me some confidence when I thought things went terribly wrong (more on that later). So I chose CQuartz UK 3.0 and Gliss despite still being dubious of coatings: 2 years of protection...IF you have a sacrificial layer for what's already supposed to be your 'super durable' sacrificial layer plus other bespoke maintenance products. Anyway it still seemed like a good choice for my car as a daily driver that lives outside. Plus I really wanted the experience of applying a 'big boy' coating under my belt (my previous coating experience was Polish Angel Cosmic V2 which was very simple to use). After reading good reviews of many CarPro products, I decided to stay in the family for other things used on this project.
My Portimao Blue M340i xDrive was a special order that I picked up at the BMW Performance Center in Spartanburg, SC (one of the best experiences of my life, do it if you're getting a new BMW). I got the car in December and used the winter to decide what to use for my LSP in the spring. I maintained it with only regular washes during winter. My first and main goal of this process was to remove some factory-installed marring and micro scratches. That was accomplished with CarPro Essense and my Rupes LHR15 Mk III polisher with a yellow Rupes pad. One of the best things I did for this project was convert my old PC 7424XP to a 3" setup to allow me to get into the primary area the micro scratches were bothering me (angled upper portion of the door panels). With the PC I used a 3" URO-Fiber pad which is the best pad I've ever used.
The COVID-19 situation played right into this project (silver lining I guess) allowing me to take as much time as I wanted without having to drive the car. I used my old barn/garage which usually only holds one car, my 2006 Honda S2000 track car. The lighting in there isn't great which is one of the biggest lessons learned through this process: do everything you can to bring as much light to the process as possible. Where I thought things went off the rails in a major way was when I noticed that my microfiber towels were leaving fibers/lint behind as I buffed off the CQ UK 3.0. I thought I ruined the car (at least temporarily until the coating could be polished off). Luckily that wasn't the case. The fibers were mobile and the application of Gliss collected them at the end of each stroke and my new emergency-buy Costco microfibers lifted them off.
Not that the folks here reading this don't know already, but CQ UK 3.0 was no joke when it came to high spots. I'd put the high spots into three classifications: 1. legit high spots where you could feel and see the coating sticking up from the clear, 2. rainbow spots where the product wasn't wiped off fully, and 3. slight dark spots where the coating was wiped off but just a tiny bit more was there. I only had one of the first kind at the base of my driver side A-pillar, two of the second kind on each side where the front fenders meet the bumper, and probably half a dozen of the slightly dark spots. The slight dark spots were only noticeable after I thought I was done and pulled the car out into daylight. A couple of the slight dark spots I was able rub CQ UK 3.0 over them enough to get the solvents to reactivate the initial coating and remove the dark spot. The others were handled with Essence and my PC since the areas were small and the URO-Fiber pad was more effective (then re-coat and re-top with Gliss).
The end result is good and I'm happy with the finish. Looking perpendicular to the finish, the gloss doesn't look too remarkable; however, when looking at oblique angles there's a noticeable increase in reflectivity. The car hasn't seen rain yet but the majority of the car has had CQ UK 3.0 and Gliss on it for a week while in the garage. The touch up spots are currently at 24h post Gliss (48h post CQ UK 3.0). At this point am I glad I did it? Absolutely. I wish I had more product and another car to do it better.
Key lessons learned for newbies using Essence and applying CQ UK 3.0 and Gliss:
  1. The URO-Fiber pad was awesome, it corrected and finished down effortlessly
  2. Having a 3" setup helped tremendously with tighter areas
  3. Do everything you can to throw as much light at the work as possible, diffuse light works even better for the coating process
  4. Use new microfibers with low pile/weight for coating removal, even if you've got a great cleaning process, don't assume they're clean
  5. You've heard it before but wipe well beyond the area you're working the coating
  6. If correcting high spots don't tape off with painter's tape, the coating darkens the finish and you will then see a line where the tape was that's hard to blend back in
PRODUCTS USED:
Wash and decon:
Meguiar's D111
Two bucket method with grit guards
Ryobi 1600/1.2 pressure washer
MTM Hydro: hose, gun, PF-22 foam cannon
Speedmaster Wheel Brush
Merino wool wash mitt - flats
Detailer's Domain microfiber mitt - sides and lowers
CarPro Iron-X
Pinnacle Poly Clay
Absorber chamois
Metrovac Master Blaster
Polish/correction:
Rupes LHR15 Mk III
Rupes yellow pad
PC 7424XP
Chemical Guys 3" backing plate
URO-Fiber 3" pad
CarPro Essence
Cobra Gunmetal Elite 360gsm microfiber
Coating/LSP:
Cobra Gunmetal Elite 360gsm microfiber (not new)
Supreme 530 600gsm (secondary buff) (not new)
CarPro Gliss
Costco microfiber towels, low pile (NEW)
Wheels/calipers:
Tuff Shine Tire Cleaner
Sonax Full Effect wheel cleaner
Meguiar's wheel brush
Kitchen sponge (for stubborn dirt on barrels)
(Same wash gear as above)
CarPro Multi-X (for calipers and wheel well liners)
Tuff Shine Tire Clearcoat
Misc:
Torin Big Red Creeper Seat
Scangrip headlamp
PHOTOS:
Here's what you're all waiting for, although it's not a super exciting transformation because it's already a new car...
These first couple shots represent the primary goal of this mission...remove these defects!
A photo of the polishing process. I gained new respect for Brian from Apex Detail, Miranda Detail, Forensic Detailing, etc.. Not only is it not easy to take pics or video by yourself, it's even harder not to charge ahead and make progress instead of having the discipline to capture everything you want folks to see. I guess tripods and big memory cards help a lot.
Now on to the coating steps. Unfortunately I did not get a good shot of what the fibers looked like on the finish before Gliss. Imagine super fine lint/fibers stretched out straight going in the direction of how you buffed off the coating. What I'm going to show you here is how Gliss collected the fibers I was worried were cured onto the finish with the CQ UK 3.0. Then the new Costco microfibers removed them all when buffing Gliss off.
Random shot of the caliper after the first wheel removal. This was post-wash but pre-deep-clean and coating.
Here is one of the high spots that manifested as a rainbow. This had to be polished off, re-coated, and re-topped. Ironically, the same thing happened at the same spot on the other side.
Now for the end result!
Damn, that came out GREAT!!
Thanks for posting your entire experience.
Great read, and awesome car! :)
You did great and you know what you are doing.
Nice Bimmer
I had a couple high spots with Gloss Coat when I first did coatings and decided against the wait.
That wipe off time is a big question mark.
What I do is apply, fold my microsuede nice and level, reach for low pile, fold nice then go over area again.
Finally I reach for a Gold plush JR and go over again.
I guess what I am saying is I don't really wait.
That rainbow high spot is a doozy. It should be a meme.
Nice Bimmer
Haha. Thanks, I'm glad you think that because it didn't feel that way at some points. It was my first time with a liquid coating like this. The only thing I had going for me was watching every CQ UK 3.0 application video YouTube had to offer!
Excellent thread! I enjoyed your write up, pics and reading about your experience! Car came out fantastic and really looks good!
Very well done!
Lots of work but that first wash will make the effort seem worth it. Now you know for next time how important lighting and the leveling towels are.
You used a 30ml kit of each product?
Correct, 30ml kit of each.
You car came out great. The color looks great. You should see it get a bit more reflective as the coating fully cures.
Take the high spots as a lessons learned as I mentioned in your other thread. It happens to the best of us when we move onto coating applications.
Enjoy the ease of cleaning and simple maintenance over the next 18-24 months.
Maybe try out the other version of Cquartz on the white one.
That bimmer is looking proper! Any plans for the white one? Got any pics of the S2K?
Nice job. Im up on a year with my CQUK3 and it’s still going strong. Gonna add a coat of Cancoat just cuz. Car looks greAt and good choice on the color.
Thanks for the kind words, guys! I really appreciate it.
I didn't mention it in the OP but the CQ UK 3.0 looks like water in the bottle but felt more like honey during application, Gliss was very forgiving to apply and remove.
Haven't decided how I'm going to maintain it yet. My wash is Meg's D111 and I wasn't planning on changing that. The CQ came with a small bottle of Reload so I have that in my back pocket. Any other suggestions?
The white car has Polish Angel Cosmic V2 on it, applied last July. It's still there to a degree but it has definitely been running out of steam faster than I think it should've. In the next couple of months it'll probably be time for something else.
CarPro Reset for bucket wash, ECH20 for rinseless and ECH20/Reload (Merlin mix detailer).
The GUZ convinced me with his comments and reviews to order some Elixir to try out.
Well actually I ordered 2 liters so I guess I will be using Elixir as a drying aid for awhile.
I started using Meguiars Hyper-wash for the regular bucket washes and foam cannon duties.
I don't know about 110 degrees but it's still decent.
Nice work!
Two things I'm a big fan of...
1) Quality microfiber towels Blend: 80/20 Gsm: 320 with a short nap and longer nap sides, make a big difference for coating removal for high spots.
Also, a sad but true note, mf towels I use to remove the ceramic coating I throw away after the job. It's not worth the risk to reuse them.
2) Good lighting! I'm a big fan of the ScanGrip MultiMatch 3 or ScanGrip MultiMatch 8 (if you have the room) and a ScanGrip Sunmatch 3.
Even then, I pull it out in the direct sunlight (direct sunshine, no clouds) and check for high spots. it can be a little tough but it's easier before it cures.
Again,Nice Work!
Beautiful work! You have another vehicle at your disposal to do sitting next to it...
Saw it posted on Bimmerpost as well.
Thanks. Tough crowd over there.
The X5 has Polish Angel Cosmic V2 on it. It has slowly been degrading so I'd imagine it will be time for something else in another 2-3 months.
Nice Job. Gorgeous Color.
Car looks amazing. The wheels are beautiful.
Good job man! Beautiful car and color too! I also see you got a fleet of BMWs and I am also from jersey too! Cheers
Thanks, guys!
I just washed the car for the first time today following the coatings. Some wind and rain blew buds from a nearby tree all over the car. Easiest wash I've ever done. Starting with the wheels, the pressure washer cleaned them completely and the beading was beautiful. The finish of the car cleaned up very easily and this is the most effective my Metrovac Master Blaster has ever been.
Some pics in direct sunlight to put a period on this thread.
