irvsmith
- Nov 8, 2014
- 611
I have been having an issue with my process or the 3D Car Soap. I have been using the Gilmour 75QGFMR and while the foam seems quite thick - I note that after the foam has dwelled for 3-5 minutes a majority of the dust/light dirt is still intact on the surface. I have tried different ratios of soap to water (1/3 to 1/2), and the foam gun is fully open to the largest opening for the maximum suds/foam.
Am I doing something wrong?
Is it the soap?
Maybe my expectations are to high for this process?
Maybe I need to reduce the foam opening so the foam is comprised of smaller bubbles as opposed to large bubbles?
Hard water?
The dirt level is what I would describe as light to medium given the car gets a weekly WW at least and I am in a urban environment. I would not expect the bonded contaminants to be eliminated but a recent example was there was a light powder of pollen (which I could fairly easily remove with a finger) and after the foam had dwelled a majority was still intact.
I am probably doing something wrong but didn't think this should be a challenge given that I let it dwell for a bit.
Thanks in advance.
Is it the soap?
Hard water?
Thanks in advance.
