JonMiles
- Jan 28, 2010
- 921
So acrylic and polymer are the two big hitters in the sealant game (thats what ive read the most about anyway)...what would be the difference between the two..and what classifies if one is polymer or acrylic?
Acrylic as used in automotive use is usually a term meaning that it contains polyacrylates. They contain a vinyl group in the actual molecular sense. They are known for a high elasticity and resistance to breakage (shattering and cracking). Acrylic polymers are also heat and oil resistant.
Polymer sealants can refer to any coating that is applied and cross links to across the surface of the paint. For instance the MSDS sheet for many polymer sealants shows the use of polydimethylsiloxane PDMS. This group when cross linked is extremely hydrophobic and causes great beading. PDMS will also flow over the surface of the paint and become level, then cross-link to form an elastic coating.
For a sealant to last a year would mean that degradation due to heat, UV radiation and various interactions with contaminates and air is very slow. To last 3 years would mean that the sealant is nearly inert to everything. However, things like rain, snow, bird crap, sprinklers, and dust can all bring a different variable to help degrade a polymer. If UV radiation from sunny days doesn't degrade it, then the acidity of bird crap surely will. If those two don't work, a sprinkler with hydrogen sulfide dissolved in the water combined with road contamination in the form of salt spray will break down the shield eventually. I'd have to call BS on 3 year sealants. The beading may remain but the protection of cross linked monomers surely will not.
