Any FullTime Detailers actually use the Cyclo Polisher as their main DA?
AdamsImport
So I got really excited about getting a DA and jumped right into the Cyclo Polisher because it was A) Bubba Proof B) Not a lot of vibration.
Now I'm wondering what I will use for any tight corners, or whether I should keep the Cyclo I don't really want to have two redundant tools and would prefer one to use for everything... especially after reading all the good things about the Flex's. Although I am not sure if the Meguiars microfiber pads will work the flex.
So I'd like to hear some experiences or advice, I still have a chance to return the Cyclo and I am a little torn. Any input is appreciated! Feed back please
Nevermind about the Meg MF working with the flex, answered my own question. Still seeking advice about the Cyclo!
I dont use it...nor would I ever consider it for myself.
I have a cyclo, flex 3401 and detail for a living. I love the smoothness, and balance of a cyclo. It never bogs down. I have only run into a few problems as far as tight spots go. You don't have to have both pads touching the paint or even both pads on the machine. It may not be as powerful as my flex but paired with the right pad or wool and it will correct wonderfully. I hope this helps. Bottomline is you can get just as much down with a cyclo.
Sent from my DROID BIONIC using Tapatalk
I was looking at the cyclo but backed off when I thought about edges, and I don't see many other detailers really using it for daily purposes. Might have a niche application?
Alright thanks ProMoDe, maybe I will follow in your footsteps and grab the flex later on too. And just have both.
Do you use the Cyclo for scrubbing carpets?
No. I have thought about it. The only thing i would use it on would be mats. Interior carpet seems like it would be tough to navigate with the cyclo.
I got to use a cyclo at one of mike's classes, and it does seem like a tool built to withstand a nuclear attack.
Cyclo for cleaning carpet? One of my best carpet cleaning tools for vans and SUV's. Foolproof for polishing/correcting when you find a combo that works. The thing is a tank! It will lay down a crazy fine layer of sealant or 845 that will even buff off in sun.
When I detailed daily I used the Cyclo almost exclusively. I think you should keep it. I have used it on carpets and gel coat boat floors with texture molded in; worked like a champ. On the occasions that I do work on a car now I prefer the Griots machine but wouldn't give up the Cyclo.
The big problem with the Cyclo used to be that it was single-speed, and the velcro pad attachment was a little goofy. But now with the variable speed, vibration damper thingies, and the regular-type backing plates, it's a different world.
You should message B & B. I know for a fact he uses the hell out of the cyclo. He would probably have some good info for you.
Thanks guys I was getting ready to abandon ship before I even boarded!
I will keep it, and just add on more DA's and rotaries as I go. :xyxthumbs:
I agree with every one of these posts except for the one where the guy said he'd never consider one. The Cyclo was my first polisher and I now use it exclusively for scrubbing carpet and mats. From time to time I slap on a set of 3 3/4" backing plates and put it on the paint just for kicks. Heck I have even used it to scrub the carpets in my entire house. I use it on every detail I do and it blows through carpet stain removal. I took the black plastic handle off of it so I could reach further under seats with it.
You've got to be careful scrubbing carpets with it because if you're not you can whack the spinning brushes against plastic interior trim pieces and crack them but same goes for a PC style machine. I'll never part with mine and probably will never have to repair it either but, If I did there's a full parts list available for it. I really wish that Cyclo would come out with a single head DA. It would probably obsolete all the other machines with free rotating spindle assemblies.
I own 2 Flex 3401's, 3 rotaries and a G110V2 also but they would all go before I got rid of my Cyclo.
You may have convinced me to buy one. I don't need it...but, I don't really need half the stuff I buy anyways, haha. :dblthumb2:
