Looking at the data sheets, APC is a generic type of product and should provide the best cleaning power. APC+ seems to swap solvent thus removes the chemical smell but there should be no mistaking that the orange solvent content is low and the alkalinity is probably the primary worker. Of more importance is that APC+ is a cationic product which means that it will be somewhat sustantive to surfaces. Exactly what those quaternary compounds we cannot say but it is probably fair to say that they are intended to persist after rinsing so the above observation about residue on surfaces is plausible. With regards to the degreaser, both products have alkalinity which will be very effective in this regard and the solvents in both products will assist - they will both degrease. As a rule, an APC is going to be similar an aqueous degreaser, often the only difference will be the name the supplier uses.
