kjimpressions
- Mar 14, 2011
- 58
I'm gonna b e purchasing one of these soon. I just don't know which one to buy. Any advice? Is the hot rod just a spot remover?
Thanks
Thanks
totally agree that it works best with hot water put into it first. cleans really wellthe mytee lite ii is 3 galons capasity the instructions says that you have to (pre-heat) the water (fill in with hot water). I follow this and works great. If you dont fill in with hot water is harder for the integrated heater to heat 3 gallons when you need it fast to extract. And the chances are that the first running water came hot and as the flows continue cools down because the heater dont have time to heat it.
does the mytee lite take out all of the stains? i have never used an extractor before
With any really bad stain you want to pre hit the stain with your choice of stain removers.... agitate, blot, then extract.... this has worked well for me over the years. Only going over it with an extractor will not get out tough stains.
I understand that, but do you go over the stain r floor mat with just hot water and let that sit for a minute. or do you just spray the water and vacuum it right up? a stupid question but why not ask right
It would be nice to see the "PSI" and "Water Lift" specs of each in a side by side comparison.
I can't see heating time really being a issue if you plan your time accordingly.
Thanks
