In the past what i have done to clearn my carpets is i went to kragen aka O riley and purchased some carpet cleaner, pulled my floor mats out of the car, sprayed the cleaner, used a scrubber brush, then rinsed them out real good with water from the hose and continued to scrub them til all the dirt and debris appeared to be gone. Then i used my shop vac to suck up any water left and laded them out to dry in the sun. They turned out great!
From what i have been reading and seeing looks like some of u are just talking about only shampooing the floor mats and scrubbing them and making them look better, correct?
just my 2 cents...
i just looked up the megs APC+ and its out of stock and has a lot of good reviews. looks like im going to have to pick some of that up when it comes back in stock!
what abouts Megs APC, not the plus, what is the differences between the 2?
We will cover Hot Water Extaction. Which is basically what you are doing. When I clean something with my truckmount it gets basically pressure washed and extracted right away. Your way is doing the same with what you got which works.
