If they really, truly, meet the criteria of being a 'Coating'...
Should manufacturers have to produce "cover-ups" for them? (Except for the "making-some-extra-money" factor, that is.)
I don't think anyone was attempting to belittle any other member. Heck I tried it and couldn't really tell the difference on my cars, not to mention it didn't hold up well. But I think I didn't hold up well as it couldn't bond properly to the coating underneath. I just didn't want to see anyone else to spend the money and be disappointed.
A "topper" product is good when having to release the car without proper cure time to protect. I also use it when doing check ups om my coating customers cars. I prefer to use same brand as coating.
That would be an expensive waste of Synergy.So Bob.....I bought PBL coating with synergy wax...do not need the wax I guess? Your thoughts please....
That's short-changing a Customer, IMHO.
That can't be helping the coating curing process... surely?
•IMHO:No, its not. This is especially important here in wintery areas due to salt and snow. Also, some clients can only afford to have their car down for a day, especially busy moms.
•IMHO:
-Yes it is!!
-Coatings, and their total cure-times, takes commitment.
Plain and simple:
-"Don't do the Coatings...if They can't do the Time!"
imo the best of both worlds is Gloss-Coat because it's ridiculously slick and glossy. once you use Gloss-Coat, you'll understand why you'll never want to put anything on top again.
•IMHO:
-Yes it is!!
Plain and simple:
it's a pretty common situation that due to the curing variables, CQ users often put Reload on top of a fresh installation and Opti-Coat users use Opti-Seal. coatings have an initial cure, then continue to get harder and harder as time advances. there are varying degrees of vulnerability during that span.
coatings aren't at their strongest in a day or even a few - it takes weeks - so unless:
1. the customer is ok with leaving the car for weeks to assure complete curing and
2. the detailer can accommodate such a request
and/or
3. even wants to take on the liability of having that car sit around for several weeks
it makes sense to apply an appropriate, compatible sacrificial barrier to help prevent certain things that can occur to a freshly installed coating job. water spotting is a common one.
as far as the OP's question, i leave the paint coatings alone after maintenance washes, once the coatings are fully cured. in fact, every once in a while i'll pre-treat with a Power Clean solution and wash with Reset to get the coatings clean so they can act like they are designed. imo the best of both worlds is Gloss-Coat because it's ridiculously slick and glossy. once you use Gloss-Coat, you'll understand why you'll never want to put anything on top again.
That's interesting since one of the big selling points of Gloss-Coat is that it was designed to be able to be topped (unlike OCPro or OC2.0). BTW I love Gloss Coat and probably would say I'm a little happier when applying it to customer's cars in comparison to the more expensive Pro version. It is an awesome product!
Read below....
And also, are you telling me you would pass up a coating job because the customer cannot leave the car for more than a day?
IR curing lamps. Problem solved. No need for extended cure time.
I'm not going to get into the coating shouldn't need toppers deal. Some guys do it some don't. to each their own.
I have used:
Kamikaze Overcoat, CarPro Reload, CarPro Hydro2, FK425, DG Aquawax, and many others. My favorites are Kamikaze Overcoat, CarPro Reload, CarPro Hydro2. All do to the fact that they enhance the coating properties that I am looking for.
In your opinion what is the best topper for a coating (I have Cquartz on one car and Modesta BC-05 on another)?
The toppers I currently own are Shine Supply Wet Detailer, Kamikaze Overcoat, and Carpro Reload.
My goal is to protect the coating with a sacrificial layer that has similar characteristics to the coating(dirt release, resistance to waterspots, scratch resistance, etc.).
Also, have any of you ever tried putting Blackfire Wet Diamond (or a similar sealant) over a coating as a sacrificial barrier? BFWD is one of the slickest surfaces I have ever encountered, in my opinion even slicker than Modesta.
