FUNX650
- Dec 1, 2010
- 21,057
- 2
^^^IR curing lamps. Problem solved. No need for extended cure time.
the hot ticket is Gloss-Coat on top of Pro, but within the Pro curing window, obv. it's like Opti-Seal topped Pro but obviously way more durable as a battery, since Opti-Seal is temporary on top of Pro, curing window or not. Dr. G says that is basically what Opti-Coat+ is.
How have you found Kamikaze Overcoat? I just ordered some to use on top of Modesta BC-05.
How long has the durability been? What coating have you used it over?
In your opinion what is the best topper for a coating (I have Cquartz on one car and Modesta BC-05 on another)?
As I see it - this is the problem with enthusiasts and coatings. The enthusiast knows that coating has lost *something*, but also knows to re-coat it is a huge PIA.
Therefore, they want *something* to rejuvenate their partially degraded coating.
I don't see any point in "topping" a coating with anything but a QD - unless your bored and looking for something to do.
To me, it just makes much more sense to use a single products that is easy to re-apply and readily renewable on the paint.
There also is the noob school of thought that thinks - the more products on the paint - the better. So, know you want an LSP to protect your coating. However, no evidence really exists that this is the case.
coatings can be impacted negatively if they are loaded up with stuff that sticks to it which often times comes from people going over and over the car with quick detailers, washes, spray waxes, sealants, etc. that's why i was recommending to keep it free of "toppers" and deep clean it every once in a while with Power Clean and Reset.
then you have the fact that the last gen of coatings was not as slick as they are now, so because of that, people want to put something on it so it would feel better, like Chris said earlier in this thread.
i think this forum has proven this over and over again. people like to do stuff just to do stuff - they don't care if it's a waste of anything, they want to do it for whatever reason. that's up to them, of course, but i'm just confirming what you are thinking.
you mean vs. using a coating?
If I get tar or bugs on my car and have to use a heavy APC or Tarminator to remove it, I know I will be degrading or removing my wax/sealant. A coating is (should be at least) resistant to these product and additionally will make cleaning these contaminants easier. That's a plus to me.I don't understand why you need to clean a coated car with some APC like Power Clean or some special aggressive soap like Reset? I thought the point of these things was nothing sticks to them and they are so easy to clean???
How come the most mildest car wash soap doesn't due?? If the paint/coating was "contaminated" - wouldn't the solution just be to clay it?
This is why I'm not too crazy about coatings for an enthusiast like me. To many inconsistent results out there with coatings that don't bead, coatings that won't bead, coatings that need special soap or toppers to keep them beading, and dubious claims about mar/scratch resistance that don't pan out.
It just seems too complicated for questionable benefits to me. Yes I know people just do stuff to do it - and that's great. But my opinion is, I couldn't see topping a coating with a wax or some silica sealant - I would just use that wax or sealant on my paint initially and call it a day.
Coatings are probably a great idea for professional detailers or someone who can't detail their car for longs periods of time. But for me, I'm all about keeping stuff easy and simple and not dealing with coating headaches.
i have two coated cars, one that sits outside 24/7...and i'm never going back.
having switched to a coating, I'm never going to look back.
jinx
IR lamps are apparently a popular solution for some CQ installers. not everyone has IR equipment, so using Reload is a common remedy for CQ cure time spot prevention when you don't have such equipment. i don't see using a companion wowa sealant during cure time as cutting corners or compromising anything or anyone, it's just a different way to get to a similar destination.
The reason for this is because with the latest formulation of CQuartz Finest (v6) we're not supposed to top it with Reload for 3 days post install. So Reload can no longer be used as a means to "protect" the coating while it's curing. IR curing lamps also harden the coating more for better scratch/swirl resistance.
if you don't have an IR lamp setup and can't use Reload with the new formulation, what is the solution to prevent spotting during the cure phase if the car is released into the wild?
or is it not prone to spotting anymore during the cure phase, hence, the new formula? just curious.
the question might arise also re: consumer CQ stuff and using Reload. similarly, as i mentioned, i'm curious how susceptible Gloss-Coat is to initial cure spotting since it's so vastly different in many behaviors and feel vs. 2.0 and Pro.
I'm not sure about if it is much less susceptible to water spots during the cure window. I believe all coatings have issues with water spots while they are still cross linking because the film is still quite permeable at that point.
Most of the pro coating installers that I know that are offering CQF are using IR curing lights, especially since the new version was released.
I know that the consumer versions of CQ can be layered with Reload within an hour after the coating installation. CQUK is recommended to use Reload an hour after installing and is even sold as a kit with Reload included.
I'm not going to get into the coating shouldn't need toppers deal. Some guys do it some don't. to each their own.
I have used:
Kamikaze Overcoat, CarPro Reload, CarPro Hydro2, FK425, DG Aquawax, and many others. My favorites are Kamikaze Overcoat, CarPro Reload, CarPro Hydro2. All do to the fact that they enhance the coating properties that I am looking for.
