Dr Oldz
Active member
- Aug 31, 2010
- 4,462
what kind of solution is it you use?
It's called Trans-Mate Extractor Shampoo.
I thought it was going to be Folex!!!!
even with our ninja
No, this stuff works great and is cheap! $15 a gallon and 2-4oz per gallon is the dilution ratio!
Folex works great and is cheap, $15/gallon. Folex doesn't change the feel of carpet fiber when it dries, leaves no residue or scent, and can be used with or without an extractor.![]()
ProHeat - $90 with stain tool and crevice tool
ProHeat Pet- $100 and has the same tools but adds the turbo brush which separately is $24.99.
So, if you buy the pet version for an extra $10 you get the turbo brush. Otherwise they are the same. I will probably gettge pet version because the turbo tool willbe nice to use on my couch.
after each use, run clean water thru to clean any solution out of heating element and wand.
