tuscarora dave
Active member
- Aug 21, 2009
- 5,408
- 12
I did this truck last weekend for a new client and forgot to take my camera with me. I spent 2 days on it and it started getting dark as i was applying the sealant so after wiping the sealant off I set it up so that I could come back this weekend and go over it with a fine tooth comb so to speak.
It was washed with ONR then clayed using ONR as lube
M-105 with orange VC pad on Makita rotary
M-205 with white VC pad on Flex 3401
The part where I am still learning is that I ran out the M-205 and then tried to wash off the polish residue instead of wiping it off as I went.
Applied DG #111 as LSP
I went back today and wiped off a lot of small traces of polish residue then did an ONR wash and then wiped it down with PB Spray & Gloss
The wheels were wiped down with DG Aqua Wax and tired got Optibond then washed with left over ONR to give a uniform new tire look with no wet look as per customer request.
Here are some after pics, you'll see the polish residue in the way of a buffer trail below the door handle in the one photo. when I suggested that that spot be re polished, the customer said it will be getting snowed on in a few weeks and that I should just let it go. While not the perfect finish it is a lot better than what I started with and the customer is happy.
It is a 7 year old truck that was never corrected before and is used as a snow vehicle and to pull a large 5th wheel camper so you all know that it had some defects to start out with. Sorry for not getting before pics all the same. Thanks for looking, TD
