Hi guys im new here and have just brought a 2007 VW jetta in black. The paint work is not great and Id like to get it looking as best I can. I used to own a red pearl Nissan Skyline and it was flawless until the panel beaters took a rotary to it and swirled it up (and denied it when I confronted them).
I had little knowledge and tried to remove the swirls with some swirl remover 2.0, and a orange pad on a dewalt orbital sander (which I didnt use correctly) I never got them out and ended up using zaino z5 and z2 which covered them but 4 washes latter they where all back.
Sorry about the long story but I don't want to half ass it this time. So I have done a lot of research here and on other forums. I came across this very interesting guy called junkman on another forum. The thread had 2 hours worth of videos which I have learnt a tonne from. Junkman goes into great detail and the guy is quiet a character.
click here to see the thread
Anyway after watching the video this is my plan of attack and this time I will do a test spot first.
Then I will wash and clay the car
Next I will use a orange hex logic pad and M105
followed buy a white hex logic and M205
then I will seal it with my zanio z5 and then z2.
I dont have a PC but a Makita B05021, which I think will do the job. I see the junkman uses his PC on setting 5 which (after some research is speed of 5800opm). I veiwed the manual on the makita and setting 2 is 6000opm.
The junkman said he uses 9 to 14lbs of pressure and to find out how much this feels like he said use some scales. I did this with my makita and it didnt stall, I found I could apply much more pressure then that before it started to slow down.
Here are some pics taken of the paint its pretty ordinary around the door handles. But in over places it has moderate swirls.
Am I on the right track here?
Do you think the Makita is up to the task?
Any advice for under the door handles? they are quiet bad
Do you think the M105 with the orange pad will be two agressive after seeing the pics? Any tips or advice would be greatly appreciated.
thanks
thanks
