VISITOR
Active member
- May 10, 2007
- 9,859
- 3
The reliability isn't so great as the unit can die on you at anytime
just like with any other tool... warranty = :xyxthumbs:
Ditto!:xyxthumbs:I love mine..
For those of us with a PCXP but not a Flex, GG ROP or rotary, what would be the priorities for #2, #3 and #4 machines if we were adding to our machine inventory?
You mean you only have a PCXP? IMO, the next logical machine to add would be a rotary. The PCXP may not be able to turn the pad adding 100lbs of pressure like the griots, but at the proper weight of 15-20lbs, it should turn a 5.5" pad just fine. My old PC is able to turn a 5.5" pad with 20lbs of pressure with no problem and it will easily knock out any holograms I induce with my makita rotary. Other than those two, I would probably like to buy the 3401 next so when I want to do one-steppers, then maybe the 3403 for its compactness for those tough to reach areas.
Man oh man! So much has changed since I started detailing! You guys that are just starting out now should feel very lucky with the tool/pad/products choices you have available to you now.
But even at speed 5 it was tough to slow this thing down! Very powerful motor!
It has tons of power!
Hello Mike,
I am currently on the market for a polisher but have never used one before. I am either going to purchase the Griot's Garage 6" or Porter Cable 7424XP.
If you were in my shoes which one would you buy and why? Please dont tell me they are both equal . They are almost the same price so the price is not a factor.
Ok Mark,
Flex DA
GG ROP
Rotary
Something else?
Congrats on getting the Griot's ROP....again Mark!
I'd like to add that I have been using the PCXP since it came out and I have zero issues with it under heavy pressure. It takes far more pressure than I will ever need to apply in order to stop the rotation. That being said I still wouldn't mind getting a Griot's machine.![]()
Mike Phillips said:The Griot's Garage 6" ROP does have the most power to maintain pad rotation under pressure from my own personal experience but here's the deal...
With either the PCXP or the GG, the amount of pressure you have to apply in order to get a thin, 5.5" pad to stop rotating is so excessive that you bend sheet metal.
You would never push this hard with either tool for correction work, it's just too much pressure for the task at hand, so while the GG may have more power to keep the pad rotating under pressure, when both tools are used the way you would use them to actually buff out the car the end result is the same, that is you put the tool on the 6.0 setting with a 5.5" pad and buff out the car.
Key point -->You don't necessarily finish any faster because you still have to move the tool slowly over the surface when you're removing swirls and scratches.
Hi Kurt,
90% of people will say to add a rotary to your PCXP. However, I tried a rotary and didn't like it at all. It has a VERY different feel than a DA. On horizontal panels I was starting to get the hang of it, but on vertical panels, what a PITA that was. Sure, everything takes practice, but I know a rotary is not for me. However, you may love a rotary. I'm pretty much set with my Flex 3401 and GG DA. :xyxthumbs:
Rasky! Thanks, bud! :dblthumb2:
I'm not saying the PCXP is a bad machine as it's been proven to do some GREAT work. On speed 6, it's not *easy* to stop the pad from rotating, but *easier* than the GG DA. That was my point.Anything below speed 6 on the PCXP is kinda worthless for correction, IMO. Do you ever use below speed 6 for correction?
