Bring back the shine on our first new to us camper (gel coat)
solar07
Hello all.
We recently bought a 2010 SunnyBrook Harmony 269 THX toy hauler. I had it detailed today and I am told by the detail guy (specializes in RV and campers) that the reason a large chunk of my camper is dull is due to the gel coat has burned off from being stored outside by the previous owner. The claim is there is not much I can do.
My question is, is this truly the case? I am told by others it is highly unlikely the gel coat is actually gone and that it is more likely oxidized or simply in need of a polish. I will say there was some white chaulky substance on the concrete after its bath that he claimed was the paint coming off since no gel coat but I feel like that was more due to the roof and it running off.
Anyway, I ended up paying for a detail that was to include being buffed and polished and that part did not happen as the claim was it could be buffed but it would return to dull in a month, They applied a liquid coating of some sort and that is the end.
I currently have the newer Meguires DA and have no issue diving into this with your guidance. I know rotarys are used on these a lot but I dont know if I can get myself to by one right now just for the camper.
Thanks for any help on how to tell what I am dealing with and next steps.
Is it that bad of shape the detailer didn't want to buff.pics would be great.
I will snag some pics in the daylight tomorrow. Being my first camper i am not sure how to tell what is in what shape.
Take some angle shots.I resurrected a 2006 F450 this thing was cooked to death,it only has 12k on the odometer.
https://drive.google.com/drive/folders/0B9YhqYk5XuBJQ0hHM3BvWGluMTA?usp=sharing
Seemed easier to upload some files to my google drive and share. Let me know if this does not work. Seemed better than hogging up cloud space for Autogeek.
I took a few angle shots of the side, some head ons, and the cap head on and angle. It is certainly shinier than what it was with the liquid gloss product they used and the bath itself. That said it is still pretty dull in spots and even when it is shiny, it is from and angle and pretty dull head on. That said, it is still pretty white. Sorry about the barn lighting.
That can be restored by the pics.mckees rv or menzerna gelcoat products will make it much better.To me seems like they didn't want to be bothered.No color products that have dye in it will stain it.Are you in fla?
With my DA? Any reccomendation on pad? How do you tell if its just dulled and scuffed versus oxidized? Is mine oxidized? Thank you so far....I read on another forum about a clean/cut, polish, wax AIO but I cant remember and wasnt sure if it would work.
Looks dull and oxidized from the pictures.with the da meguairs marine onestep compound and polish with the rupes foam cutting pad should improve the finish.Then wax it with some collinite.Giving advice over the forum is kinda hard in a situation like this.If that was presented to me that's what I would try first.I have loads of different compounds,if one deosnt work I try something else till I find the dial in process.you don't have that option.So I'm gonna say that system behind a keyboard is not defenitive.There is no short cuts on time working on finishes like that.I do many rv but finishes are different in oxidation wise.So unless someone wants to chime in do as you wish.look into meguairs line gelcoat or mckees line for gelcoat.
I am actually in Ohio. Are you in Fl? I wish someone with your knowledge and products was around here. :/
I'm curious, how often will I need to cut qnd polish? The gel coat being only so thin I am curious hiw often this will need done. With a good sealant and being under a roof I am hoping I won't need to polish all the time. Over on the RV forum I being told the polish will only last 2-3 months.
subd, Can you please keep updating this post. I recently bought a 5th wheel toy hauler as well and is in the same shape as yours.
Im thinking about buying this kit but im kinda nervous because it is pretty expensive and not sure if it will work.
FLEX XC3401 Marine 31 Boat Oxidation Removal Kit, gel coat oxidation removal (maybe you can try these products not including the flex of course since you already have a DA, and see how it workout
Rule of thumb when working on rv is to look at a angle.If there is sheen more than likely you can restore it.Im working on a 2010 ithasca if I spelled it correctly,baked to death everywhere never been taken care of since 2010. My approach to this is to quickly sand it down with 2000 then polish.By sanding it cuts so much time rather than to spending so much time machine compound.when sanding you will not get high and low gloss spots on the side which look terrible with machine polishing.
Sonax cutmax works very well on gel coats.I really don't think there is a standalone compound that will restore gelcoat even with diminishing abrasives.To much work and mess and added time to the job.when sanding your just gliding it over the gelcoat,not killing it like your really sanding.Ive tried them all with no success.Better and quicker results by nibbing it down with 2000 or 2500 the gloss and clarity is no match when you compound it to death only.
I am trying to fully comprehend.. So is your recommendation to go with a 2000-2500 grit sandpaper then to do a compound such as Sonax? Or sand and then straight to some other sort of polish?
What are you guys sealing it with after and how long before it needs sanding again?
Thank you all so much so far...
Also, how are you guys sanding? As in what tools and approach?
I'm sanding by hand.I don't like using a machine on flat gelcoat especially around all the windows and outlets and other small things on the rv I like to see what's going on while sanding.Do not sand any run down water streaks where water constantly escapes from the top.Keep in mind your just grazing the finish with 2000 grit just to knock off the dead fadeness.Then I'm using sonax cutmax with a gg6 da with a wool pad with steady slow overlapping passes.some tight areas I'm using my Ibrid to compound around Windows.Then on a da with orange foam thin pro bringing up the gloss with menzerna gelcoat fine cut and gloss.Then lastly sonax brilliant shine detailer.This is day 3 I'm piece mealing this in between other jobs.you may not want to sand over graphics as well,but on this one I did it was so bad.
2 choices of products that do work,is menzerna gelcoat system you get the compound and the the fine cut and gloss and the top coat for protection.or the meguairs marine cleaner.
you should never sand it again,keep on top of it with some collinite 845.This rv is going to a consignment up for sale so my job is to make it shine and dont go crazy with durability lsp products.
Great info. When you say stay on top of it, how often do you recommend?
As for the sanding, what is your queue for when an area has been sanded enough that the fade and dead has been taken care of? Wish one of you knowledgeable folks was in Ohio.
