So are you reccomending the vert or poli? Trying to follow. Thanks!
You will be adding to the promblem with that stuff.
What is the coating you speak of? It is winter here now and everything is in the barn.
No update yet. I just received my needed products to start polishing in the coming weeks. Seeing the results of the spray and forget I am a little unsure as to how to proceed. In test spots it is doing something remarkable. Question is, how will it hold up or will it cause any harm?
My advice? Use something that is actually designed for what you're working on. This includes not using a floor wax on an RV. I don't profess to know any of the chemistry involved. But I do tend to think the people who manufacture those products do and they design them to have the optimum results for the surface they're made for. Also, if the Spray and Forget is powerful enough to remove oxidation without any buffing on your part, I'm suspicious of what else it's doing to your paint. You can't get something for nothing, and I have yet to see a product that delivers results like buffing without any effort or any work. If it seems too good to be true, it probably is.
My opinion: you're received some great advice from a world-renowned detailer (Mike Phillips). Go with what he suggested.
Scratch that. It helped some but still getting a bunch of weird inconsistent dull marks ��
It's hard to tell. Looks like dried on product. You're using a cleaner wax??
Hello all, so I finally found time to do this. Camper is all washed and in the garage with my marine 31 heavy cur cleaner wax, lake country yellow foam pad, and Meg's MT300. I'm running into a few issues.
Right out of the gate one of my lake country pads melted to the center of the Meg's 5" plate. Only 3 sections into the job. I chucked that back plate and switched to the yellow one I see Mike always using. So far ok.
Still on the front and I'm getting some very shiney results in some areas combined with some dull lines, trails, etc, like you can see where I was with the DA. Any tips?
See where light is shining there is like what looks to be foot prints on a window.
Link to my album will have to do for now. It won't let me upload photo from mobile device.
Yea it is marine 31 heavy cut gel coat cleaner wax. I did one whole side and the front and got mixed results. I tested meguires ultra cut then a polish and it looks better so I'm thinking this may not have enough cut.
Might try another one step like captains. Do I need to use a wool pad?
Thanks Mike. Yea I've tried it a few ways (more product, less product), Meg's cutting pad vs the lake country pad. I seem to get the same effect. I spot tested an area using Meg's cutting product, then a Meg's polish and it turned out great. Hoping not to have to three step this however.
What pad do you recommend with the black fire?
I'm not sure what the issue is with my Meg's DA. It seems to get very hot on anything past setting 4. Even if I one hand it and use no pressure with my left hand it still seems to start getting hot. I eased way up and after awhile, and continuously changing pads, I managed to partially melt the yellow back plate as well. I'm wondering what's up with that.
On a side note I have test spotted some areas doing 2-3 runs with the Marine heavy cut and I get the same smudgy results each time.
How much product should be left on the camper/on the pad prior to buffing?
Thanks again.
