They are my favorite microfiber pads. They are the perfect size and after months of using them I can confidentally say they are the most durable microfiber pads on the market. Lake Country HDO Microfiber is also very impressive.
For a long time I was using Boss MF Cutting pads but for the cutting process I would have to swap out about 8-10 pads per vehicle. The foam backing on the boss microfiber makes the pads very smooth but if you are using a compound that isn't lubricated enough, or you use too long of a buffing cycle, the foam will twist and rip away from the hook and loop backing.
The uro-fiber pads on the other hand. (I only use the 5 inch version) utilize a white open cell foam that is truly perfect. I now only use 2 uro-fiber pads for my cutting stage and I wouldn't be surprised if I could get away with using just 1.
One feature I really love is the size of the 5 inch pads which are an exact fit vs meguiars pads (which I know lots of guys use with long throw polishers)
They also run extremely cool and finish good enough that I can use them for AIO applications with HD Speed on normal/hard paints.
They cut just as much if not more than boss microfiber pads
Since I've never used Megs Microfiber pads on my MK2 15 I'm not sure how they compare to megs in cut.
Below you can see how perfect they fit on my Rupes 15. It's hard to see in the photo, but I have not had any issues with the backing plate bumping trims or door handles. I don't like the excessive overhang the meguiars pads have.
