IMO the uro-fiber cuts just like any other microfiber cutting pad, yet finishes like a foam cutting pad. I would compare it's finishing ability to the Maroon Uro-tec pad if not a little better. This is just my opinion but I think once you use it for the initial cutting stage especially on soft paint you will see why it's such an amazing pad. I think too many people are assuming that it CAN'T be used with a heavy compound because it's marketed as a 1-step microfiber pad and they emphasize it's finishing ability. IMO, it is best used on a large-throw polisher like any other microfiber CUTTING pad.
If it really cuts as good as Meguiars, then i must get these in all sizes! Durability is great too?
Btw do you guys prime microfiber pads? I usually do, but they work without priming too, i should do side by side test.
