Like said above use a 4 inch pad, orange, yellow with some compound. I will be waiting on the Flex, thanks.
O.K., you don't have to prove it to me, I know it is possible. My point is before making a statement that the pc can not burn paint, you should make sure it is a 100% fact. Just because you haven't burned the paint with a pc doesn't mean it isn't possible. Will it take longer than a rotary, yes, can the pc burn paint yes. As far as a pc easier to use than a rotary, that is up for debate. I feel there really isn't much difference if you pay attention to what you are doing. It isn't the tool that causes the problems, it is the user. It just gets old seeing people post that you need to start with a pc before getting a rotary, that is bs. Any tool can do damage in the right hands or someone that doesn't pay attention to what they are doing.
Well, drat. I was hoping it would burn through just so I could see what a burn-through looks like. But at least Rasky is saved, at this point, from having to give Rocket a new Flex. But if you're in the mood, Rasky, to give away Flexes, I'd be happy to be gifted by one.
Al
There you just pointed it out that it will burn the paint. Never heard of melting the paint and I have been using a rotary for over 20 years and have wet sanded over a 1000 cars. So I will be expecting a Flex.
Hi Rasky, sorry I did not see your post. I use the speed 5 or 5.5 when I was doing paint correction. The vibrations came from me pushing really hard when doing paint correction as from what I have read, you are supposed to apply 15-20 pounds of pressure. Polishing is nice and easy and pleasant, but paint correction is hard. I must admit that I was probably applying closer to double that amount of pressure when doing paint correction because I thought that over-doing it wouldn't have any negative effects, whereas under-applying the proper amount of pressure wouldn't get the job done properly.What speed setting are you using for correction?
I have to agree with Risky on this one; you cannot actually burn the paint with the Porter Cable. There has been no amount of pressure and extended period of time where I have been able to get the pad or the paint surface to be anything more than warm to the touch when I was doing my car.
Well then you should know the term of burning the paint, it is a rub through. So when do I get my flex.
The paint getting burned is a common term that has been used before I starting doing this. If you want to get that technical with a definition that is fine. You can take the easy way out of not knowing what you are talking about. If you look on other detailing forums burning the paint is used
as a rub through as you want to call it. It is obvious that you need to learn more about this and the terminology that goes along with it. I am also sorry to the orignal poster since he/she is being mis-informed of "burning the paint". Plus I really would like to see paint "melt", that just shows you have no clue to what you are talking about. It is people like yourself that get on these forums and make statements that are incorrect and the newer people pick these up and are misinformed.
lets all work together versus coming apart ... the forum is to teach and help and we aim to keep it that way.
