Then applied a healthy amount of Iron X and let it dwell for 5minutes (bottle says 5-7min).
I did notice SOME reaction but not on the areas I expected. It didn't attack my yellow/orange spots (which are littered all over my car).
That's interesting as my experience has been if you see orange spots on the paint that's a sign of rust staining caused by iron particles embedded in the paint.
Perhaps try decontaminating with the Iron X even if you're not seeing a lot of iron bleeding.
Then mechanically decontaminate using a Nanoskin Autoscrub pad on a PC.
Then... try a test section of Iron X again just to make sure and see what happens?
If after all of the above you don't see anything I'd say you're good to go.
When I chemically decontaminated Stacy's MB there wasn't a lot of bleeding and this makes it hard to capture the bleeding with a camera but here's what I was able to get.
I used the Auto Finesse Iron Out but it works on the same chemical principals as Iron X.
Removing Iron Particles out of Mercedes-Benz Ceramiclear Paints
Following the steps outlined in my how-to book, the next thing to do is decontaminate the paint. For this I'm using
Auto Finesse Iron Out Iron Remover.
Bleeding-Effect in Mercedes-Benz Ceramiclear Paint
Light Iron Contamination
These pictures show the paint was in fact lightly contaminated with some type of iron particles...
And for everyone reading this into the future....
The BIG PICTURE
Yeah yeah yeah... I know, everyone loves seeing the
bleeding-effect when using an Iron Remover because it
looks cool. Kind of like how everyone loves seeing water bead-up after it rains on a freshly waxed car.
But here's the deal... while you do want to remove iron particles out of your car's clear coat finish for a number of reasons, in the big picture, this is a process you want to do, (to make sure any iron particles are removed), but in reality... you really don't want to see the bleeding-effect as this means your car's paint was in fact contaminated.
Iron contaminated paint indicates corrosion and deterioration of the clear coat has been taking place and because clear coat paints are THIN this is a bad thing. This is especially true for Ceramiclear paints because the very top layer or shell of a Ceramiclear paint is only around .2 mils for the nano particles of Fumed Silica which provide the scratch resistant characteristics that everyone loves about this type of paint.
:dblthumb2:
