Is there any way to reduce the amount of dust your car collects... if not, is there a way to remove this dust with out QD the entire vehicle.. like a cali duster or something and do those things even work ?
Use a spray detailer and a high quality microfiber towel, making sure you only use each side of the MF for ONE SWIPE to avoid cross contamination. Buff with a clean MF once all dust is removed.
I'm using Wolfgang sealant with collinite 845. V07 is my QD
I use the CA Dustbuster and it works great!
The CA Dustbuster MUST BE USED CORRECTLY. If not, it WILL scratch the paint. Used right and it works great. To use the Dustbuster BARELY TOUCH the car. Just enough to where the strings are just hanging and gently brushing the car. It will remove the dust. The other is the sidekick blower.
I use the CA Dustbuster and it works great! The other is the Metro Sidekick. The Sidekick blows the dust off.
The CA Dustbuster MUST BE USED CORRECTLY. If not, it WILL scratch the paint. Used right and it works great. To use the Dustbuster BARELY TOUCH the car. Just enough to where the strings are just hanging and gently brushing the car. It will remove the dust. The other is the sidekick blower. That can blow the dust off. If the dust does not come off, then you will need to wash the car (I foam gun 2-bucket wash) no questions.
It is possible to do a rinseless wash, however, a regular wash would be the preference.
:xyxthumbs:
Good advice if you want to use the duster. I don't use it often, but when I do it is great and I have never scratched the paint - and I have two black cars, one with extremely soft paint.
Even so, I still prefer using a waterless wash or quick detailer. You can doing it surprisingly quick, just a bit longer than the duster. Unfortunately, dust is a part of life...
