allenk4
In time out
- Mar 12, 2013
- 4,845
Eraser is great if you're using CarPro products. Other than that, I'm hesitant to use it because CarPro openly admits that it leaves something behind for anti static. This concerns me if doing a wipe down prior to using non CarPro LSP's. I may try top inspection
This is from the CarPro USA website:
Eraser also has anti-static components to resist dusting after wiping. The paint will stay dust-free while you’re in the process of applying Cquartz so you don’t have to keep re-cleaning panel by panel.
It does not appear to state that it leaves something behind.
Maybe it is like a DI water wipe down; which is supposed to neutralize the static charge, but obviously leaves nothing behind.
