Klasse Act
- Feb 21, 2012
- 27,799
- 2,881
I have this product coming to me via AutoGeek (thank you everyone there) and I have a few questions that you may or may not be able to answer.
First off the ratio in foam cannon. Now I don't have a foam cannon but what I do have is a soap dispenser for my Worx hydroshot, think of it as a "poorman's foam cannon". The advised ratio is 1:9 and just to make sure, that's 1 part Hydrofoam and 9 parts water, correct? I ask because not having a foam cannon maybe the ratio is backwards from what I'm accustom to seeing, usually the higher number is first which means water and then the 2nd number is product, just wanna clear the air there. I plan on using distilled water in the dispenser because I know I'm not going to use the entire contents of the soap dispenser and I don't want it to break anything down over time.
Next is temp, how warm do you think it needs to be? Having access to the underground garage allows me to wash my cars when its cold outside but as with any protection the 60 degree rule may or may not be in effect, I wanna use the product but I don't wanna waste it because its only 45 degrees down there. I do have access to my buddy's vinyl shop where its always warmer than 60 degrees, so either way, I'm going to be able to do it in warmth if its completely necessary.
Finally for those who've used it over time, how's the durability?
