Carpro PERL advice
I love PERL. I have a 5L coming!! Use it for everything
Like what? :D
I've done some testing on ext. plastic trim and liked it, but I have DLux coming so I won't need it for that anymore. So I'm curious what uses you found for it!
That being said I use a foam tire applicator and I use it straight - undiluted. If you look at Just's pictures of his @ 1:1, that is really shiny. Not hating, just saying that my tires when I use it straight are not nearly that shiny.
You get shiny tires from diluting? Is it not the opposite, diluting will give less of a shine?
Yes, when you dilute perl the gloss diminishes. However, spraying it on increases gloss when compared to wiping it on. This leads me to believe that wiping it on only yields an uneven coating while wasting product. I've pretty much already proved this to myself by getting more gloss at 1:4 than when wiping on at 1:1. I'm all for a consistant tire dress coating while saving product! My clients have also never been happier with the look on their tires! :-)
Oh ok that makes sense. I was confused for a second lol. more glass at 1 part PERL to 4 parts distilled water with a sprayer? I'll give it a shot with one of those little airplane-safe sprayers. Thanks for the tip, sounds like the sprayer makes it go on smoother and faster.
I'm going to set up some 1:1 and 1:4 dilutions and try it again on my wheels the next time I have an opportunity to work on my car again (my garage is being torn up and remodeled).
I think there must have been some sort of product on the wheels that was left behind by the guys who took the tires off when powder coating my wheels; perhaps I just didn't clean them enough.
Maybe the Carrand applicators work better for the thick gels.
Kevin I suspect it was the rain 12 hours later. Looks like streaking to me.
There used to be a lot of guys complaining about PERL being used on anything exterior, when water came into contact with it causing streaking. It'll work better on softer stuff than harder in that regard. And the sooner the water, the worse the streaking.:eek:
FWIW, I keep it mixed at 5:1, 3:1, & 1:1 but refused to use it on tires. (Much prefer Opti-Bond!) ;)
I have used PERL on exterior soft vinyl, and even tried it on tires (as a test) many moons ago. Soft porous vinyl like you'd see on a vinyl top, or better yet, a tonneau cover.... it'll work wonders on, and NOT streak. But ONLY after it's been baked in with the sun.
I have a client with one of those aluminum reinforced (push it forward and it rolls up into a box at the front of the bed) tonneau covers on his Tacoma. When I first got ahold of it he had NEVER serviced it, and it was at least 6~7 years old. Took over an hour of scrubbing by hand, cleaners, brush on the GG6, lots of rinsing, lots of prep to get it where it wouldn't wipe black on your fingers. Then we put it in the sun for about an hour to dry. Pulled it in the shade to cool, and thoroughly soaked it (via sprayer) with PERL @ 3:1. Let that soak in for 15 minutes or so, wiped it with Costco MF then pulled it into the sun for 30 minutes. Back into the shade, cooled again, repeated the process.
It was really nice afterwards, not perfect, but nice. The day was running long and we had to return it, and I explained what we'd done but told him I wasn't happy with it. He OTOH was super satisfied with it. None the less, next day I went by his shop with the bottle of PERL and went over it in the sun. After that second (well it was the third actually) application we didn't have to touch it for almost 8 months. Even after rain, washing, you name it.... PERL had sealed the pores of the vinyl.
Had it rained overnight however, it'd all have gone to junk! :rolleyes:
Reviving an old thread... for those who recommend spraying vs wiping perl on tires: How do you manage against over spray on the paint and wheels?
Just wipe it off..water based dressing.
