Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
-Just a FYI:
Some of the shiniest vehicles I’ve ever detailed had exactly no LSP applied to them. True story.
I know a guy in this industry that used to say this all the time, and while it may be true, the results won't last over time as the polishing oils are water soluble. It is the application of the LSP than enables the results to endure over time.
This is why I always say,
Wax is the great equalizer
Or
Synthetic sealant is the great equalizer
Or
Ceramic coating is the great equalizer
It is the application of the LSP after the last polishing step that shmoos over the surface and thus shmoos over the surface to create a uniform appearance (that will endure over time), and that in some case, may tone down the results from polishing.
Here let me go deep down the Rabbit Hole....
Also - the application of an LSP will create a more uniform appearance that I don't think polishing can achieve as there are a few variables in the polishing step that cannot always be trusted to create a 100% perfect appearance over 100% of the car. This is where the LSP will pick up the slack. Those factors would include things like
Who is doing the polishing and their skill level - pretty easy to figure out there are some people that are true artists with a polisher in their hands and a larger majority that are simply "good".
The paint itself =Paint is always the unknown variable - this means in any given detail job, the end results may not be dependent upon the person, the product or the tool, the car could simply have crap for paint. I dealt with this at my lass class.
Then other things like abrasive technology, pad choice and tool choice - but a true artist will already have his system dialed-in, kind of like any true professional car painter.
Number of pads used - can't create perfection when pad structure changes and or becomes contaminated. Too many people using too few pads from what I've seen over the decades.
Just waxing on at length now.... pun intended....
:bolt:
