Desertnate
- Aug 5, 2013
- 6,239
- 292
I experienced the same conditions the first time I applied it, and it turned out to be putting the product down too thick. I also think I may not have shaken it up enough and applied an improperly mixed combination. The thick areas were also hard to remove.
Since that first time, I've put it down much thinner using my DA and never had any removal or sweating issues. It's really an easy LSP to use.
I don't know if weather is a factor with the hazing problem. I've applied 845 in temps ranging from upper 50's F to low 90's F and humidity upwards of 70% with no issues at all in any of those applications.
