6supersport7
- Oct 22, 2009
- 233
I have heard bad things about the new formula for dp epoxy. Many people say that it will come right off with thinner. It may very well be great stuff though. I used SPI epoxy on my last project and was very satisfied. You can do you body work first or over top of it. If you miss your recoat times, all you have to do is go over it with a scuff pad. If you are wanting to avoid a lot of headache, you are going to need a lot more then just a water trap on the compressor for shooting color and clear. Compressors get hot and make a tone of water. A typical setup would probably consist of 50-75 ft of hard line at varying angles with multiple water drops and filters. The air has to have the room and time to cool for the moisture to leave. There is a lot to a good paint job and materials can be expensive. Go to your local jobber, they can usualy be very helpful with what you will need. Good Luck.
