swanicyouth
- Mar 3, 2011
- 9,388
Any idea on how to REMOVE it? Applied over a year ago
IME - that's the problem with this product and why I no longer use it. This is my experience with DLux on plastic trim on a daily driver parked outside:
Product initially looks / works great. Product lasts a long time. After a LONG time (1 year +). DLux starts to "oxidize" ( don't know if that's what's going on chemically, but it looks like oxidation to me). You try to remove it, and it's literally impossible to remove it 100%. It's about as easy to remove as dried up Krazy Glue on plastic. So, the solution seems to be to clean and apply more DLux. IPA will not touch DLux once it's cured. Neither will any detailing product designed to clean plastic, APC, or even solvent based stuff like Prep All IME.
However, now the DLux last significantly less time - maybe 3 months and you are back where you started... I would only recommend using this product as a last ditch effort on already damaged trim. On healthy trim - use a trim sealant.
