of course you could throw a sealant or wax or anything, and it will be super shiny for the first few days, but how long will it last without being applied properly?
i've run into a conundrum of sorts in my head, thinking about my early times in doing detailing related things, and trying to super strong ipa dilutions which i believe (after a lot of research) to be bad for the paint anyway now, and stick to much less concentrations like 10%.
after enough reading you too would find yourself wondering things about what is good and what is bad. the consistency of threads popping up about stripping LSPs and all of the posters who swear by this and that, i even purchased some CG CW+G hoping it would readily strip any waxes left on the surface, because i could then reapply a sealant over the top of whatever was left of my last sealant and be done with it.
but then i remembered that it has a G in the name. Citrus Was And Gloss. this pretty much seals the deal for me that if i plan to use a sealant after the wash then this is not my go to soap. as it leaves a layer of gloss and surfactants behind that are going to interfere with the bond i want to get so i don't have to reapply for another 6 months (weather depending).
I've gone through looking at possible polishes and recommendations on polishes that could be used to give a clean working surface, and polishing seems to be the only real clear cut way to get a clean and clear surface for applying a sealant for proper bonding (so they claim on the labels). but what about all of the oils left behind from the polishing, we have probably all been to that point where you think you got the panel perfect and then give it a quick wipe with an ipa solution and you see a horrible (or what looks horrible in your eyes) collection of fine swirls still in the paint, because they were filled by the oils of the polish.
one would say that after you completely polish the paint, you just give it a quick wipe with ipa to check it and make sure it's clear of oils, or you wash it one last time, but how can you be certain that the panel you are looking at has no oils or fillers left? do you as professionals or enthusiasts do a multi-stage wipedown with ipa and special cleaners before applying? do you pick a carsoap, which will have surfactants for lubrication, and do a final wash and re-apply that ultra thin millionth of an inch thick layer you just tried to get rid of because the soap says it doesn't have it, but actually does? will the layer of things you just put back on by using almost any car wash out there, hinder your sealant application that much?
so i'll pose these questions and see what everyone's definitive answers are as i've gone through many posts and articles on the topic. but can't seem to find out for certain what is really going on on the molecular level.
1. if you chemically strip your paint for a sealant, which requires bare paint (going by the general recommendation on most sealants), and do it with something like CG wash and gloss, is it just a placebo effect that all these people believe that the wash and gloss really does strip wax off because it says citrus? or is there something else at work here like using such a high concentration leaves behind a layer you don't really want that prevents beading (it is a very very concentrated soap btw).
2. if you use a glaze or m205 as suggest by mike phillips to help remove an lsp (in another thread on stripping), and you go to remove those oils left behind from the polishing process, what can you really use besides ipa at 10% to ensure that you really have no oils left on the paint.
3. Does anybody really trust doing a final wash on a car before applying an lsp, knowing that most car washes if not all have some kind of film that will get left behind, whether it beads or not?
4. how many people have simply just tried using something that was designed for removing waxes, like a paint prep product such as ppg dx330 (wax and grease remover), meant for prepping panels before doing the actualy paint job itself. i feel like we are all looking in places where the answer isn't found.
5. how safe do you feel when you go to apply your lsp sealant again, after having done a round of sealant with a wax on top only a month ago, the shine seems to be fading so it's time to do it again. but do you really know if your paint is prepped enough to just reapply, or is the reapplication of the sealant a crap shoot unless doing a full polish again to remove any remaining wax that could hinder the sealant application.
i know i'm not alone in asking these questions after reading so many threads on it. so maybe some people will have some good answers to questions that i feel were't touched on much, it seemed the topic was always steered towards what got the paint to the point of being "stripped", instead of if the paint was merely in an acceptable condition to apply product to it and have it last a decent amount of time. has anyone really tested whether a properly prepped panel and a panel with next to no prep besides wash and clay had any difference in durability?
