Not trying to be a smart a$$, but have you ever used a rotary? From your very basic questions it doesn't appear so. You can do a lot of damage if you dont know what you are doing.if foam is a better choice, which pads will fit on the 7" hook n loop that came with the package? should i start with the lighter wool pad (since there are two in the package) and finish with a foam pad (meguiar 8006)?
